TX 99 Gst Eclipse Barcelona Red Pearl
Old Jan 21, 2012 | 07:58 AM
hotdoggies's Avatar
Default 99 Gst Eclipse Barcelona Red Pearl $4500
Im selling my 99 Gst eclipse. In no Rush to sell! So NO LOWBALLERS! Iam the second owner and the car was stock when i bought it from a older woman. It was a 1 owner car. The Timing belt, tensioner, and all pullies have been replaced less than 3k miles ago. Have reciepts. The lifters have been replaced with the revised 3g lifters. Have reciepts as well. I have reciepts for everything. Engine is solid has mid 150's compression on all cyl. I have replaced cam seals, valve cover gasket and it has a new valve cover. Replaced slave cylinder and master cylinder for the clutch. All maintenance has been done. The transmission is smoothe and does not grind at all. New southbend clutch. A/c works and everything else works. New tint Even has original Infinity Sound. I have the original window sticker as well. Gs wheels with Toyo rubber. Car went through Pdr to remove most of the door dings. Car looks great! Original paint is good 7/10 id say. 145k miles. Clean title. 5802351546 name is Brandon
The late model 98 and 99 Gst came with a flashable ecu much like the Evo ecu and came with a washer motor to alleviate crankwalk.The Ecu has been reflashed so it has a antilag system when in neutral and revved to 3800 rpm. It is basically like a standalone. It also uses the stock boost gauge as a knock gauge. I have spared no expense and do not cheap out on parts. All parts are quality as you can see. You will not find another Gst cleaner, much less a 99 for this price.
Engine mods-
FpT28 turbo
K&N intake
3'' Catback
2 1/2'' DP
No cat
Turbo Xs HPBC
Greddy Hard pipes
Greddy Type S Bov
Greddy FMIC
Apexi Neo
Aem Wideband
Prosport Boost gauge
NEW stage 4 clutch 6 puck
Uploaded with ImageShack.us
Old Aug 16, 2012 | 06:14 AM
hotdoggies's Avatar
Default Re: 99 Gst Eclipse Barcelona Red Pearl
TTT
Old Aug 16, 2012 | 09:46 AM
Mr.Chow's Avatar
need a price on this bud.
Old Aug 16, 2012 | 11:46 AM
hotdoggies's Avatar
My bad. Fixed. Could have swore i put it on there.
Old Aug 17, 2012 | 09:26 AM
hotdoggies's Avatar
SOLD!
98lsdc
Jul 21, 2017 06:17 PM
timnewton23@gma
Mar 19, 2017 08:17 AM
hotdoggies
Texas -OK -LA (Sales)
Jan 22, 2012 12:04 PM
TegoDC5
20
Dec 8, 2004 09:24 PM
