Need help getting rid of my abs light.Can you help?
Old Jan 21, 2012 | 02:32 AM
slicked91's Avatar
Default Need help getting rid of my abs light.Can you help?
well ever since i got my 95 integra ls its been on i need suggestions on what to do.
Old Jan 21, 2012 | 04:46 AM
Mr. EG's Avatar
Default Re: Need help getting rid of my abs light.Can you help?
Pull the ABS code and proceed from there. There is a handy thread in the FAQ section if you do not know how.
Old Jan 21, 2012 | 11:36 AM
Whiterice-gsr's Avatar
unless u dont want abs anyway pull out the gauge cluster and unplug it.
Old Jan 21, 2012 | 12:47 PM
mark@silbernage's Avatar
Search Google for: reset ABS light integra
Occasionally it comes on and simply needs resetting. If there's an actual malfunction, the code will return.
Mark
Old Jan 21, 2012 | 12:56 PM
el crapitan's Avatar
or you can just leave it. when a malfunction is indicated, the abs system is disabled.
i think what i'd do is just check the code. make a note of it. clear it. then see if it comes back
Old Jan 21, 2012 | 01:05 PM
slicked91's Avatar
yea i did pull the cluster off and it didnt work but im gunna go ahead and check out the reset code and see what happens.
andrey320
Feb 11, 2016 04:37 PM
scottyyhz
Honda CR-V & Element
Dec 30, 2014 04:46 PM
tjwebber17
Suspension & Brakes
Jul 2, 2011 10:15 AM
vti-R
Dec 26, 2001 08:59 AM
