b17 rotating assembly over b16a.. worth the effort/money???
Old Jan 20, 2012 | 05:49 PM
blaccrex's Avatar
Default b17 rotating assembly over b16a.. worth the effort/money???
so a guy kinda local is selling a b17a crank and rod and i have a b16a sb with a spun bearing... will the b17a make a noticeable bump in power over the b16a? ive always wanted to do this mini "stroker" setup but dont kno if its worth my time n money.. or just repair my b16a? or put in a more simple question, what kinda power output does an average b17a putout? (intake, header, exhaust, cams)
Old Jan 21, 2012 | 04:42 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: b17 rotating assembly over b16a.. worth the effort/money???
Since you spun a bearing and that's going to require an engine rebuild anyway, you might as well upgrade to the b17A crank. You'd probably have to turn down the old crank anyway. The b17a crank will give you roughly 10 more hp and tq and I can't see how it will cost you much more money.
Old Jan 21, 2012 | 05:51 AM
snm95ls's Avatar
I got 150 dynojet WHP with just 96+ GSR cams, a JG Edelbrok header, and a tune on my old stock block B17A1.
I would go for it if the price is right.
Old Jan 21, 2012 | 08:40 AM
slick1851's Avatar
Whats the point when you can make it a 1.8 for just as much money?
Or do a LSV?
Seems odd to put the extra time into something that will net lower gains.
masterbuilder
Aug 7, 2007 07:14 AM
todapowered
Feb 23, 2006 03:20 PM
irev210
Dec 23, 2001 06:07 PM
