Add rear sway bar to 95 LX
Hey guys,
I have a 95 Civic LX that I bought a few months ago. A big thanks to Honda-Tech for the excellent writeups which helped me do the timing belt and some other stuff.
I'm interested in adding a rear sway bar, just a factory 13mm version since I'm just commuting in it. Looks like I need to snag the lower control arms and the sway bar and various links and brackets from one of the following cars:
92-95 Civic EX
94-01 Integra or GSR
Can someone please confirm that the parts off of these cars will work for this application? Are there any others I could be looking for? Thanks!
92-95 Civic EX
A simple search would have told you everything you needed to know, but I am bored so I'll help..
You can take ALL of the parts from any 94-01 integra, or 92-95 that has a rear sway bar.
You can also use a 99-00 SI sway bar, however, you would need to run aftermarket endlinks.
LCA's with the endlink hole
Sway bar.
Sway bar bushings.
D brackets, with bolts.
Bracket that goes from the d bracket to the subframe with bolts. There will be 4 bolt each side. (2 on d bracket, 2 on subframe mount)
2 endlinks.
EDIT- If you run a EG/DC bar run their endlinks. if you run the 99-00 SI, you will need to run aftermarket as the bolt holes are different for the endlinks. I am 99% sure you would need to run a adjustable endlink.
Sway bar.
Sway bar bushings.
2 endlinks.
beginmyhonda
Nov 19, 2010 05:22 AM
luispizarro25
Aug 6, 2009 08:26 AM
