p72 pistons in b18a1
Old Jan 20, 2012 | 11:24 AM
hellraiser6's Avatar
Default p72 pistons in b18a1
Wanting to put these pistons in my motor. Is there anything that I need to do to make this work? or a better alternative?
Old Jan 20, 2012 | 11:28 AM
Rad Racing's Avatar
Bart Taylor Look-alike
Default Re: p72 pistons in b18a1
Simple answer is yes, but what are your goals? N/A? Boost? What kind of head? If you're concerned or curious about compression this can be your friend:
http://www.zealautowerks.com/bseries.html
Old Jan 20, 2012 | 01:41 PM
right now i just want to have a functional motor NA. The motor I have in it now has blown piston rings. Not real sure the extent of the internal damage. Have a 2nd b18 that I got when I purchased the car. Just had no pistons. Managed to get some p72 pistons and rods and was told that they would not work because the rods are narrower than the ls pistons.
Old Jan 20, 2012 | 04:12 PM
ANYONE? ANYONE? BUELLER? BUELLER? ANYONE?
Old Jan 20, 2012 | 04:57 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Hush child.
P72 Pistons - sure...
P72 Rods and Pistons - No, not unless you want the piston to hit the head.
P72 Rods, Pistons, and Crank - Sure, but why would you want to destroke it?
You are better off getting some PR3/P30 pistons and calling it a day.
Old Jan 21, 2012 | 03:18 AM
Thanks for the help...just not the child comment!
Old Jan 21, 2012 | 03:53 AM
DO IT ON ALL FOURS
You are welcome for both! Remember to stay in school and respect your elders!
Old Jan 21, 2012 | 04:11 AM
I am probably as old or close to your age!
Old Jan 21, 2012 | 05:06 AM
DO IT ON ALL FOURS
I give "blanket advice". Regardless, I somewhat doubt that - especially from the movie reference. It is all fine by me either way you look at it, but the rules don't allow bumping was all I was getting at. Back on topic, do you have any other technical questions?
PS - Just in case you were wondering: The LS rod is the same width on the small end as the B16/B17 as that is why I posted that picture for reference.
Jeanious
Dec 4, 2007 12:41 PM
TurboJesse
Apr 5, 2005 03:42 PM
VTiVTo8000rpm
Jan 19, 2005 05:48 AM
Nextelbuddy
Dec 31, 2003 11:44 AM
