Bouncing Temp Gauge?
I have a 89 SI and these last few days only at night when all electrical is on (Headlights Heater Radio) i notice temp Gauge moves up and down when i drive away goes back to normal also the battery sounds like its going out in the morning battery is nearly dead just enough to start battery is 5 years old. Is it time for a new one?
Same thing was happening to me turned out my battery ground cable was loose on one of the connections
But a battey test at autozone wouldn't kill you either
you guys are right in the back of my mind i keepdt thinking i have a bad gound connection i have a cheesey pepboys ground connector to my neg - post i will replace it i notice i even have static noise thru speaker with the heater on that will be my weekend project>
i had a similar problem but mine was worse. when i turned my brights on both my gas hand and my temp hand spiked out fully. also the starter turned slowly. turned out it was the main ground wire, it had corroded really badly
kingofnothing
10
Aug 21, 2010 05:26 PM
allentownrep
May 19, 2009 11:37 PM
Tad
64
Sep 21, 2006 05:42 PM
