Rear seat removal help
there is a 10mm bolt holding it down in the back not the front were the hooks are on the driver side get it off pull up the back first and the hooks will release.
Just take your hand and feel around the center towards the back. you cant see it unless you take the backs out. It's kindda hard to get to with the backs installed but once you find it you can stick a socket on it and use the extension to push down on the cushion. It's in the middle, halfway mark.
