98 accord tps and iac codes
Old Jan 19, 2012 | 05:41 PM
angelyno55's Avatar
Default 98 accord tps and iac codes
Hi everyone ! I have a 98 accord, 2.3l V-Tech, wich gives me a lot of headache. I replaced the other day the intake manifold gasket and knock sensor. After i put it back together, the engine would not run properly. When i'm trying to accelerate, it almost dies. Like no aer or enough gas... I have four codes, wich are: P0122 TPS, P0113, P1519, P0325. Have no idea what could happened.
Any advise would be greatly appreciated.
Thank You in advence !!!
Old Jan 20, 2012 | 10:47 AM
holmesnmanny's Avatar
Default Re: 98 accord tps and iac codes
I'm not sure about 6th gen, but on 5th gen it's possible to switch the map sensor and tps sensor connectors.
Old Jan 20, 2012 | 12:35 PM
angelyno55's Avatar
Yeap, that was the issue. i just swaped the plugs and, there you go, works just fine.
Thank you so much!!! Now i can sleep well
Old Jan 20, 2012 | 01:39 PM
No problemo.
bdpackard
Aug 9, 2017 04:21 PM
civicracer94
Jul 24, 2006 05:40 PM
chpracing
Feb 5, 2004 12:24 PM
