Rear Triangle Glass
Yes, all OEM replacement glass pieces we order at the dealer are stamped "Honda" on them. Goes for the quarter glass as well. The VIN is not printed on them, just the Honda stamp...so technically, yes the glass could've been replaced with a new OEM glass from the dealer so it would be difficult to tell.
and im pretty sure nobody makes aftermarket part either, i use to work in the parts department in the body shop at my local honda dealership and i had a integra come in and called ever source i had and could not find anybody that sold them aftermarket
so the quality of yours is oem, but if you are worried the car might have been wrecked, dont look at the window it self look at the surrounding area around the window, you should be able to tell if its been repaired
Is the black surround piece able to be replaced separately? because on my car where the sharp angle that points to the rear of the car is has shrunk a bit and slightly lifted off the body.
RACEPAK
Jul 18, 2007 07:07 AM
