Del sol Color
Old Jan 19, 2012 | 05:05 PM
salaamq's Avatar
Default Del sol Color
Looking for a color to paint my del sol. I'm not looking for anything ricey, just something that'll look good. I currently have milano red on it, half of it is stock and the front end of it, including the doors, looks like it has been re-painted and clear-coated. The clear is already flaking and there is drips in the paint. The rear end is all faded and full of swirls, it really just needs re-done. If I can get a slightly darker/deeper tint of milano red, something that won't fade over time and will have some good depth/reflection to it, I'll put that on it. I would rather not get into tearing the whole car down, I just wanna paint all the outside and door sills so I can move on with it. Any ideas on a good color? I like the stock Samba Green Pearl, and the Captiva Blue Pearl, and then there's my Milano "Red". Also like a graphite color.
Old Jan 20, 2012 | 11:47 AM
jasoncrashtech's Avatar
Default Re: Del sol Color
color changes do require you to tear the car down. otherwise the jams will be a different color and if you can like the job after that it's on you.
the red is fading on your del sol because it's single stage probably. honda shot many cars in single stage in the 90's and less as it got closer to 2000.
Old Jan 20, 2012 | 12:08 PM
Builda'Teg_92's Avatar
Iv never heard of a production honda using a single stage paint? have any examples?
The milano red is a tri-stage paint and requires a red mid coat as apposed to your other color choices that are both 2-stage i believe. I was going to re-spray my car milano again but with out the mid coat it dident look right to me. The guy at the shop said a laser red might do the trick but i just picked a diffrent color.
Old Jan 20, 2012 | 03:06 PM
many, cut and buff o.e.m. paint on a red or black 94 or 95 civic or integra. then watch at your buffing pad change colors.
Old Jan 20, 2012 | 03:53 PM
ofthesun94's Avatar
Go with a lacquer 2 stage paint im painting my del sol right now candy apple red check out tcpglobal.com great prices and a lot of colors
Old Jan 20, 2012 | 07:09 PM
lacquer isn't a good way to go. thermal plastics as automotive paint is a thing of the past and has been that way since the 80's
Old Jan 20, 2012 | 07:22 PM
ofthesun94's Avatar
lacquer is the best paint and last longer than any other paint on the market water base paints are no good bro but what do u recommend urethane?
Old Jan 20, 2012 | 07:42 PM
hannslebo's Avatar
Go with a few cans of rust-oleum...
Old Jan 20, 2012 | 08:06 PM
Davis Del Sol's Avatar
Im doing mine Yellow... I think its one of the better colors for Del Sol
http://www.cardomain.com/ride/292532...-honda-del-sol
Old Jan 21, 2012 | 11:30 AM
salaamq's Avatar
I'm not very fond of Candy Apple red. Looking for just a darker tint of Milano Red. Sherwin-Williams quoted me around $500 for all the primer, paint, and clear in Milano. Sound right?
@Davis- that is a NICE sol
Old Jan 21, 2012 | 11:39 AM
That's about right if there giving you the mid coat as well, why Sherman? The only line from them I heard was good and worth using was the AWX line. Not sure how much that cost, just sayin.
Old Jan 21, 2012 | 11:42 AM
O yeah, please don't use lacquer.
Old Jan 21, 2012 | 12:11 PM
not true at all. i've been a collision tech seven years, thats one of the dumbest statements i've heard.
Old Jan 21, 2012 | 12:27 PM
salaamq's Avatar
Theres so much confusing stuff online from the suppliers that I donno what to get. Plus sherwin is just 45 minutes away, my mom used to work there a long time ago
Old Jan 21, 2012 | 12:38 PM
what is confusing you ?
Old Jan 21, 2012 | 12:41 PM
Look in the phone book for paint stores and call around, don't be afraid, they usually love to help. I went with PCL primer (I really like)...Limco paint (I like)....and omni clear (don't like so much).
But try to sty with the same line of products if you can.
Old Jan 21, 2012 | 01:45 PM
salaamq's Avatar
I'm confused about all the paint types and what type/brand/coating to get. Base/clear? Tricoat? Two stage? I'm confused? I just want to strip the car down, prime, paint two coats so it doesn't fade, and clear, then cut and polish so my car and look new again.
Old Jan 21, 2012 | 02:11 PM
ofthesun94's Avatar
What is it about lacquer you dont like I've been painting cars for 10 years and cant find anything better!!
Old Jan 21, 2012 | 02:28 PM
ofthesun94's Avatar
that is way too much go to tcpglobal.com and order your kit sherwin will knock ur head off
Old Jan 21, 2012 | 03:31 PM
Have you looked? lol
Urathane lays down easy like lacquer but has the durability of an enamel, it's the best of both worlds. Lacquer is yesterday's news.
Old Jan 21, 2012 | 03:36 PM
ofthesun94's Avatar
I know they dont spray lacquer on cars anymore but i guess its just an opinion ive just had good results with it. I just sprayed my sol with it go check it out in my garage it turned out great I still gotta clear it
Old Jan 21, 2012 | 03:50 PM
it doesn't cure (it will dry, solvents will leave but not cure) . it's not durable by it's nature, i could remove the paint off the car with nail polish remover or paint thinner.
not to mention voc's it puts in the air.
Old Jan 21, 2012 | 03:55 PM
ofthesun94's Avatar
i'll look into it thanks for the tip
Old Jan 21, 2012 | 04:00 PM
NOFX's Avatar
H-T White Ops
Milano Red isn't a problem to have on a car. I have a 1998 Civic and it stayed plenty deep and red as long as you take care of it. I'd take care of any paint color.
