NEED HALP ASAP - EM1 rear calipers question
Old Jan 19, 2012 | 04:07 PM
dwkt's Avatar
Default NEED HALP ASAP - EM1 rear calipers question
so me and my brother are doing my rear brakes, pads and rotors, and we cant get the caliper back on because the piston is sticking out and wont go back in, we've tried squeezing it back with channel locks but they wont budge. please help thanks
Old Jan 19, 2012 | 04:11 PM
grumblemarc's Avatar
The Grumpiest
Default Re: NEED HALP ASAP - EM1 rear calipers question
Release some pressure by opening the bleeder. You're going to have to bleed the system anyway.
Old Jan 19, 2012 | 04:12 PM
Former User's Avatar
Old Jan 19, 2012 | 04:13 PM
BWFL's Avatar
Try a "c" clamp. it's what i used when changing the fronts. i'm sure it'll work. make sure the pads are in properly too.
Old Jan 19, 2012 | 04:23 PM
98civdx's Avatar
Master Detailer
The rear calipers need to be twisted WHILE pushing in.
Also, poping the bleeder can help.
Old Jan 19, 2012 | 06:35 PM
dwkt's Avatar
Thanks Honda-Tech you guys all came clutch.
Just to update we did use a slotted screwdriver to rotate the piston and it went in. I did take off the master cylinder cap and we did not need to open any bleeders.
THANK YOU
Old Jan 19, 2012 | 06:37 PM
Humphrizzle's Avatar
twist the piston like a screw in a clockwise motion. it will thread back to position.
Old Jan 19, 2012 | 07:06 PM
dwkt's Avatar
lol thanks man, not sure if you saw my post right before yours
Old Jan 19, 2012 | 07:14 PM
:/ i dont read after the first post unless i need an answer. i just answer and hope it helps.
eurocrx
14
Sep 13, 2010 01:52 PM
wantboost
Dec 2, 2005 10:37 PM
mystikteg92
Jul 31, 2004 07:33 PM
twotone
Oct 11, 2002 05:11 PM
