F/S NJ Honda Short block Dart
Old Jan 19, 2012 | 03:42 PM
Hndbst's Avatar
Default F/S NJ Honda Short block Dart
I have to sell my engine parts that I have, if interested in any parts email or leave message on here. Thanks for looking.
Hndbst@aol.com
Short block assembly
Dart Engine B20 84.5 mm bore $2800.00
Eagle Rods $350.00
CP pistons $590.00
Eagle crank $599.00
Machine work and bearings $600.00
It was machined and assembled to specifications that came along with the internal engine parts, Has New Bearings and thrust washers.
Break in has not been performed.
$4500.00 obo
B16 head Stock complete w/Intake $450.00 obo
ARP Head Bolts part # 208-4306 $120.00 BNIB
LS Vtec kit, oil line and dowels w/ plug for head and fittings $60.00
Skunk 2 Cam gears B Series part # 304-05-0200 $200.00 BNIB
Skunk 2 Cams Tuner Series B Series part # 305-05-0140 $600.00 BNIB
GSR transmission Hydro w/half shaft, has approx 70,000 miles on it. I did not drive on this unit, however the person I bought it from had it pulled from an integra that was daily driven and it was in a rear end collision. No damage to the unit.
$650.00 obo
Competion Clutch Light Flywheel B series $200.00 BNIB
Hasport ef to b series mount kit w/ hydro kit $300.00 obo Used
Hasport ef to b series shift linkage $125.00 NEW
B20 Factory crv crank 97 - 01 $150.00
B20 crv head 97-01 complete minus dist
Eagle rods for D series engine approx 500 miles on them, like new in box.
part # CRS5394H3D $ 250.00 obo
D series Turbo Manifold Log style $100.00 obo Slight rust, never used.
HF manifold $30.00
92-95 D series ex transmission $300.00 obo
Zex turbo Cam 59300 used for approx 500 miles $175.00 obo
Long block D16y8 engine Has approx 98000 miles on it $500.00 obo
I also have Numerous D series intake manifolds some are complete some are not, mostly Z6
ask for pricing on what you need.
D series Oil pans $30.00 each some need cleaning.
D series timing covers upper and lower $20.00 set
D series Crank pulleys mostly Z6 $ 20.00 each
D16y8 exhaust manifold and down pipe, no heat sheild $75.00 obo
Pass and driver front door 90 - 93 Acura Integra windows $50.00 both
90-91 honda Crx back hatch w/molded wing missing glass, great for plexiglass $200.00
90-91 Honda Crx front cross member great shape $60.00
D series coolant pipe with thermostat housing $30.00 each
D16y8 short block w/oil pan rec rebuild $150.00 obo
Old Jan 19, 2012 | 03:54 PM
goldhatch94's Avatar
Default Re: F/S NJ Honda Short block Dart
any pics on the block?
Old Jan 19, 2012 | 04:29 PM
Hndbst's Avatar
The short block is still @ the machine shop. I havent had a chance to pick it up. I should have pics in a week or 2.
built94dc2
Jan 27, 2013 04:38 PM
Hndbst
Jul 11, 2012 05:48 PM
dustinbs144
Mar 4, 2012 08:43 PM
1993gsrcivic
Mid-Atlantic (Sales)
Dec 20, 2011 04:14 PM
k3vin337
Northeast (Sales)
Feb 18, 2009 07:23 PM
