94 honda civic swap
Old Jan 19, 2012 | 06:57 AM
Jhicks's Avatar
Default 94 honda civic swap
im trying to put my b18a1 in my 4 door civic. what all stuff do i need? and how do i do it?
Old Jan 19, 2012 | 07:10 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 94 honda civic swap
This is what you would call a "Frequently Asked Question".
See this thread.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
And check out this link.
https://honda-tech.com/search.php
Old Jan 19, 2012 | 07:19 AM
egvtec's Avatar
See this thread.
https://honda-tech.com/forums/showthread.php?t=1998336
Am i really seeing this? Someone else who actually helps direct someone to the search and gives out the helpful info as well?
Old Jan 19, 2012 | 07:46 AM
Jhicks's Avatar
ive been told that i have to get diff shift linkages.
Old Jan 19, 2012 | 07:48 AM
The Grumpiest
Who is telling you people this stuff?
There are quite a few swap guides in the FAQs. Pick one. Follow it. If it doesn't mention shift linkages then don't worry about shift linkages.
These swaps are pretty common so they can be as difficult or as easy as you make them. The info is out there.
Old Jan 19, 2012 | 07:55 AM
Jhicks's Avatar
i was told that the link on the civic is a diff size than for the b series. im new. ive been researching it but ive had no luck. im so damn confused bc i se one thing then i see another.
Old Jan 19, 2012 | 08:01 AM
The Grumpiest
This is from the first link I picked up.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/b18a1-swap-95-civic-2728046/
Originally Posted by forcefedferio
he is 100% right.
You need to re-use your OBD1 harness, aside from plugs being different the DA integras shock tower plugs are flipped reverse from a 5th gen civic. Unless you want to swap over your entire chassis harness taking steps backwards when a factory obd1 LS computer can just be had for cheap.
For linkage you need either 94-01 integra (any model) or 99-00 Civic SI.
For engine mounts you can reuse your main 3 stock mounts (tranny, rear mount on the subframe, driver side top mount.) because your car is a 95, meaning it has the correct style driver side mount already. HOWEVER you WILL need the post mount for the driver side from a 94-01 Integra (any model) or a 94-97 Del Sol VTEC (dohc model). You will need a rear t-bracket mount from either a 94-01 Integra (any model) 99-00 Civic Si or a 94-97 Del Sol VTEC (dohc model) and MUST be from a manual transmission. From the previous 3 models i listed you can also find the correct tranny torque mount and AC bracket torque mount.
For a transmission i strongly recommend ditching that cable transmission and putting a hydraulic one in, but whether or not you want to do the conversion is entirely up to you.
Old Jan 19, 2012 | 08:03 AM
The Grumpiest
Here's all of Google.
https://www.google.com/search?q=b18a...w=1920&bih=900
Old Jan 19, 2012 | 08:06 AM
The Grumpiest
Every single one of these that I've read so far says to use the linkage from the Integra. So stop listening to whomever is "telling" you this stuff and actually read what others have done.
Old Jan 19, 2012 | 09:10 AM
Jhicks's Avatar
i guess im just going to put a d16z6 back in it. im too broke for all that. lol besides, its my daily driver.
Driftking77
Feb 7, 2010 03:58 PM
SilverCivic03
Honda Civic (2001 - 2005)
Apr 13, 2009 07:16 PM
nicko360
Mar 9, 2007 05:09 PM
~Aj~
Mar 23, 2006 01:59 AM
darkd1gt
Mar 14, 2006 04:44 PM
