Best coilover for your money?
Old Jan 18, 2012 | 10:21 PM
ChaSu17's Avatar
Icon2 Best coilover for your money?
I have some cheap coilover and very rough/bumpy ride. What is the best coilover that is under $1,000? 2000 Acura Integra Type R! Thanks for your help
Old Jan 18, 2012 | 11:47 PM
RGoose18's Avatar
Default Re: Best coilover for your money?
Search is your friend, this has been discussed 1,455,324,334,222 times
Old Jan 19, 2012 | 12:07 AM
itrQ's Avatar
A lot of people will point you in the Koni/GC as it is a proven setup. This is food for thought as well.
http://www.tune2win.com/index.php/pe...t_3_track_test
Old Jan 19, 2012 | 06:28 AM
SpoonREVS's Avatar
Im actually in the same boat as you are. im looking to track my R and upgrade the complete suspension...
But there's not alot of information on actual test on suspension with a Type R...
I want to up grade my
Control arms, front and rear,
bushing trailing arms, sway bar etc...
brakes setup..
but most of the info I find is really old with old products or for civic's.... or a None Type R integra witch any suspension is a huge gain LOL...
Old Jan 19, 2012 | 06:30 AM
SpoonREVS's Avatar
Members if you actually have upgraded suspension and have actually track you car please post your setups and how you feel with your setups..
Old Jan 19, 2012 | 06:46 AM
Slow@ssLuda's Avatar
With your price range I'd go with the Koni/Ground Control setup. That's probably what I will do down the road.
Old Jan 19, 2012 | 08:08 AM
00TypeR's Avatar
Running gc/koni's with 550/600 spring rates. The car is mainly tracked. Will eventually go stiffer and and revalve shocks. If you are going to do the "occasional" track day I would get a little stiffer than ots rates. But they are a great setup.
Old Jan 19, 2012 | 10:29 AM
Todd00's Avatar
I said I don't want a title!
brakes setup..
Again...you need to search this forum. We've been over this topic quite a bit and there is no need to repeat it again, especially when not much has changed from a few years ago.
Old Jan 19, 2012 | 01:19 PM
Big Phat R's Avatar
"smooth ride" depends a lot on your spring rate but also the quality of the dampers (but also the quality of your tires and your tires pressures)
The setups mentioned previously are best bang for buck -- I wouldn't go with a spring rate higher than 600# unless you are going to reinforce the unibody
Old Jan 19, 2012 | 02:11 PM
FULLYBUILT2.0's Avatar
KONI + GC = YOUR ANSWER!!!!
Old Jan 19, 2012 | 04:27 PM
RGoose18's Avatar
Since we're beating a dead horse anyway on this thread......has anyone found a super cheap place to pickup a koni/gc setup??
Old Jan 20, 2012 | 07:29 PM
1GreyTeg's Avatar
My place went out of business so sucks to be you. And them of course.
Old Jan 20, 2012 | 07:35 PM
_twenty's Avatar
I picked up a set of Koni Yellows/GC setup with top hats for $650.
The difference is night and day to stock and you definitely feel more confident in the corners.
Old Jan 20, 2012 | 07:36 PM
racebum's Avatar
www.thmotorsports.com for koni/gc. rates are subjective
the 550F / 600R mentioned is absolutely the most i would ever consider on a stock sport. the rears start getting floaty
a hot street combo is 500F 450R which maintains a more neutral car. having a slight rear bias is faster on the track and lets the car rotate easier, it's just more dangerous on rainy highways.
as for replacing arms and all that garbage. all you need to do is replace the bushings. there aren't any benefits to aftermarket other than spending lots of money and having pre loaded bushings. none of the aftermarkets have done anything worthwhile like add caster adjustability to the front.
just choose your bushing. hardrace will last longer than energy but they are softer and harder to install
energy suspension makes the easy to install poly bushings but the front control arms are toast by 40k miles
Old Jan 20, 2012 | 07:46 PM
1GreyTeg's Avatar
What Spring rates and what shocks?
Old Jan 20, 2012 | 07:55 PM
_twenty's Avatar
I believe 425 front 300 rear
Old Jan 20, 2012 | 08:03 PM
1GreyTeg's Avatar
Don't believe, know before you discuss shocks.
What shocks are you mating then?
Old Jan 20, 2012 | 08:35 PM
_twenty's Avatar
Old Jan 20, 2012 | 08:46 PM
1GreyTeg's Avatar
Dewd I could post similar pics of my springs on shocks with different numbers or course.
What exactly are you're shocks?
Are you ready to buy these? Or are they already istalled in you car? How much does your car weigh with/without you?
Are you going to cornerweight it?
Old Jan 20, 2012 | 08:48 PM
1GreyTeg's Avatar
Mow much mileage on them and what type of use? when were they manufactured?
Old Jan 20, 2012 | 09:24 PM
_twenty's Avatar
I bought the Koni Yellow/GC sleeves from a friend who used them for daily driving for about a month but decided to buy a different car.
They're already installed and it's a 95 EJ1 (no idea how much it weights)
I've always been involved with motorcycles so this is my first car which I've added "modifications" and based on my previous post, it's obvious I don't know much.
Old Jan 20, 2012 | 09:51 PM
racebum's Avatar
rears are a little light. 425/300 will understeer pretty bad. switching out to the 380lb spring in the back or even 400lb spring would really balance the car out
Old Feb 2, 2012 | 05:07 PM
JustDoinMej2's Avatar
[QUOTE=_twenty;46718514]I picked up a set of Koni Yellows/GC setup with top hats for $650.
Where the hell did you buy them at!?
from what i hear they go twice as much
Old Feb 2, 2012 | 06:12 PM
Robert Singleto's Avatar
a buddy of mine(jerzey908) runs the koni/gc combo with extended top hats and his ITR is slamed on the usdm 15's(205/50/15)...yet his car rides really smooth...he also said it was a blast to drive at expo11 as low as it is. His suspension is all OEM ITR exept for the koni/gc's, i think he paid around $1100 w/custom spring rates shipped to his door. I run tein flex($300 more) we really cant compare ride quality because im runing the jdm 16's(205/40/16)but i will say as of right now he has the smoother ride and his car sits lower, tires size could be the difference in ride quality but i guess him&I will have to wait till we hit Road Atlanta this spring...As RaceBum said the koni/gc are #1
Old Feb 3, 2012 | 01:14 PM
itrSteez's Avatar
No reason to even dispute... The Koni/GC has always been an incredible bang for the buck.
