NY CRX Si fiix it/parts car
For Sale is a crx i slid into a ditch a couple years ago, its been sitting in the barn ever since... It can be straightened and would only need a bumper, bumper lights, and maybe a fender, or could be used to make a clean shell road worthy.
The car is originally from NJ, i bought it with the stock A6 clapped out and in serious need of replacement, and put a d16z6 from a 94 ex coupe in it. The chassis has a little rust and has one small bubble over the driver side rear quarter. Its black and an original SI. The interior is all stock, and the seat although worn is not ripped, although the cargo cover is pretty trashed.
The motor has mild port work, and has a port matched d16y8 intake manifold with a ported LS throttle body. The bottom end is stock other than having the oil pan tapped for a turbo return. The motor is not currently in the car but comes with it. The transmission is a stock SI tranny with an aftermarket LSD in it, if i remember correctly it is an OBX. It also has a short throw shifter.
Suspension wise the car has a full poly urethane bushing kit, D2 36 way adjustable coil overs, ITR front brakes, slotted rotors, wagonvan brake booster, and DA integra master cylinder. It also has integra 4 door sway bars.
I have a bunch of spare parts that come with it as well, including most of a turbo kit. I have a couple intercoolers, dsm bov, a pile of piping, two turbos (to4b and k26), and most of the stock suspension stuff. It also has the stock ecu and a chipped PS9 ecu thats running turbo edit with one wire vtec. Ill also throw in the chip burner and any chips i can scrounge up.
Im looking to get no less than 1000$ for it, its located in 13760, and i wont part it out, i want it all gone. I cant seem to get my pictures to upload so shoot me an email at ridenismo@gmail.com
haggar
Mar 13, 2005 12:40 PM
