EF Problems, needs help!!!
Old Jan 18, 2012 | 06:43 PM
jceltalentoso's Avatar
Default EF Problems, needs help!!!
i have an ef with b16 obd0 after install an itr im ,my car star to burn the same fuse again and again .. the fuse that make the cluster and all the rpm work is getting burn every time i drive, i don't know what to do plus i have a code 10 i checked the iat sensor and all the connection and everything look good and the check light is on before i switched to this itr everything was fine no check engine.... almost forget vtec dont pop i check the switch pressure and vtec solenoid and works fine
Old Jan 19, 2012 | 03:57 AM
jdmef69's Avatar
Default Re: EF Problems, needs help!!!
The manifold it self won't cause fuses to blow. Did you take off a ground or anything and forget to put it on? Also For code ten is your iat bad.
Old Jan 19, 2012 | 05:49 AM
krh0003's Avatar
Check for missing grounds and pinched wires. If you pinched a part of the harness it could be causing the short.
Old Jan 19, 2012 | 02:23 PM
Thanks and i Will check it an let you know what happens !
N'viouzEF9
20
Jan 22, 2011 07:54 PM
dirttrackracer
Dec 13, 2007 10:52 PM
MaL1TiA
Feb 4, 2006 09:03 AM
EFB16aJP
Jul 13, 2005 02:13 PM
