1990 crx si with v6(jswap) for sale
car:
1990 crx si
new installed sunroof
needs a paint job
sumped fuel tank
1000hp aeromotive fuel pump with filter
purple bwr tow hooks
interior:
has most plastics interior pieces
good condition crx si seats(drivers has a rip)
no carpet
ap2 s2000 cluster
battery relocated to hatch
metal battery box
exterior:
16 inch konig air max(silver)
kill switch is located by tail lights
all white body but red passenger fender
extended wheel studs only in front
suspension:
skunk2 pro suspension
energy red bushings all around
-10 line traction bars
purple blox racing lca's
motor:
j35a4
tl-s heads
tls pistons
cl-s trans (6 speed lsd)
exedy 1 clutch
dual mass flywheel
hasport mounts
hasport axles
car was made into a hydro instead of cable
rpm systems conversion harness
k-series shifter
after market header
ecu with immoblizer removed
aeromotive fuel regulator
the swap was done professionally by Don at RPM systems, if you do not know who he is do some homework. I have reciepts showing that he did my swap. There is nothing wrong with the car just needs paint n carpet, it runs beautiful and is fun to drive...
best way to get intouch with me would be by text @ 845-520-1801.. text anytime
for pics go to the link... http://www.j32a.com/showthread.php?t=1880
1990 crx si
needs a paint job
sumped fuel tank
interior:
no carpet
ap2 s2000 cluster
metal battery box
exterior:
suspension:
motor:
j35a4
tl-s heads
tls pistons
exedy 1 clutch
dual mass flywheel
hasport mounts
hasport axles
k-series shifter
after market header
