98 Civic ex has no electrical power whatsoever
Hey guys i have a 1998 ek coupe ex model it has a b20z2 swap and that's it nothing special about it just bone stock. I don't get anything i have power going to different parts but nothing turns on I have no ignition, aux, headlights, horn, radio not a single thing. I have been testing numerous things through out the day and everything checks out the only thing that comes to mind is the fuse box under the hood... I'm thinking the electrical "checker" that sences current going to it went out and even though everything is getting power it won't kick on please give me some kind of feed back I've been reading the forum like crqzy and can't seem to find anything with this type of problem thanks
Check grounds, and connections at alternator, and battery. Try putting in a battery that you know is good and see if the same thing happens. Check all your fuses, check all your connectors, test for power coming in and out of the fuse boxes.
My grounds are good, I have checked to see if another battery would work same thing, fuses all checked out even after fuse box since I am getting power to my cigarette lighter and other components (radio)
I'm confused in the first post you said radio or nothing works then in next post you say its working. Like Ron said check that under the hood fuse
bump2pass
Apr 4, 2016 07:29 AM
milehibuff
Feb 10, 2012 08:05 PM
