Lighting HID/Xenon kits, Retrofits and Associated Topics
90 accord retrofit
Old Jan 18, 2012 | 08:52 AM
bdmlilburn's Avatar
Default 90 accord retrofit
MORIMOTO MH1 WITH E46 REPLICA SHROUDS - INSTALLED IN BLACKED OUT STOCK USDM CB7 HEADLIGHTS
sorry for the poor picture quality. will post pics of light output as soon as possible. currently running 6k hids with theretrofitsource relays
Uploaded with ImageShack.us
supplies used:
theretrofitsource:
-morimoto mh1 projectors
-e46 replica shrouds
-relays
dremel tool
painters tape
bbq black paint
jb weld
jb putty weld
needle nose pliers
electric tape
6k h1 hid kit
stock cb7 headlights
Old Jan 19, 2012 | 10:02 PM
mitch6's Avatar
Default Re: 90 accord retrofit
AWESOME! I love these retrofits, they look so sick!
you did a good job! having to use jb weld and puddy is a pain!
I did one to my eg, check it out!
Old Jan 19, 2012 | 11:03 PM
bdmlilburn's Avatar
very nice what kelvin hids you using? yes the jb weld is kind of a pain but not too bad. the putty on the other hand...i would rather saw my hand off with a butter knife.
for the price these projectors are amazing. anyone ever tried a retro on a truck or do they sit up too high. i got a 90 c3500 and an extra pair of mh1s
Old Jan 21, 2012 | 06:56 AM
Joon Joon's Avatar
what did you guys use jb weld for? to mount the shroud? if so you could have used the centric rings
Old Jan 21, 2012 | 09:39 AM
bdmlilburn's Avatar
i could not see a way to mount the shroud to the projector with the projector and shroud by themselves. i got an extra pair though so ill try and figure this out for my next retro possibly into my c3500 or my gfs 02 accord
Old Jan 21, 2012 | 12:52 PM
Joon Joon's Avatar
use the centric rings.. no need for anything else.. i personally dont use them, i use epoxy not jb weld..
Old Jan 22, 2012 | 11:09 AM
bdmlilburn's Avatar
thanks for the tip. just wondering but why epoxy over jb weld?
Old Jan 22, 2012 | 11:48 AM
Joon Joon's Avatar
easier to work with and could still easily be taken off if needed
Old Jan 23, 2012 | 04:41 AM
mitch6's Avatar
I did not have to use jb weld or any sort of glue for my retrofit and little to no cutting. However my friend needed jb weld for his FX-Rs into his BMW. His were not quite as simple as mine, because of the size of the projector, as well as design, you cannot simply screw them in.
As for using jb weld instead of epoxy, its all personal preference and using what you have available. Jb weld is very good because it is very stong, if you know what you are doing the first time jb weld will do the job well so you will not have to worry about any problems arising later. I dont know about you but I would not want to have to remove or take apart my head lights once they are done. Once there done I should feel confident about their durability and functionality. That's just my opinion
Old Jan 23, 2012 | 05:16 AM
mitch6's Avatar
I'm using 4300K morimoto bulbs
Old Jan 23, 2012 | 11:48 AM
bdmlilburn's Avatar
cool i used jb weld because i wanted mine to be 100% permanent. also jb weld is very heat resistant so i can remove the lens to clean/replace it or yellow out the high beam reflector in the future.
im definitely gonna be switching to a lower bulb temp. i like the look of the 6ks but i want more light on the street.
now i just need some good fogs. had some 3k fogs but im beginning to think i like the light of the yellow halogen h3s instead
Importn2oRacer
Mar 15, 2010 03:09 PM
blurry454
Aug 14, 2009 04:51 AM
AccordVT
Lighting
Apr 7, 2008 12:45 PM
nocable4me
Feb 20, 2006 09:53 AM
NightHawkC5
Jan 31, 2004 06:29 PM
