91 integra check engine light :/
Old Jan 18, 2012 | 04:40 AM
Boost305's Avatar
Default 91 integra check engine light :/
Hello honda tech i'v had this little problem on my integra for a while and its stopping me from doing a retune my car is a 91 integra da9 b20b vtec on boost its tuned on chrome using a p28 on 2lbs tuner had to stop cause he wanted me to fix my check engine light before he kept tuning so iv read up forms and all and none seem to help me on how to find the code from the light.when i start my car it stays on all the time and never goes away,also my car tends to idle a bit up and down from time to time but idles fine when it wants too, whats the best way to check this code iv tried a few times but failed maybe someone could help, it would be really appreciated thank you, mike
Old Jan 18, 2012 | 10:08 AM
Boost305's Avatar
Default Re: 91 integra check engine light :/
fixed.
Old Jan 18, 2012 | 10:23 AM
DirtyDA9's Avatar
On 2lbs? What's the point of even having a turbocharger then? lol.
Are you asking how to find out what code it is throwing?
Old Feb 14, 2012 | 03:00 AM
Boost305's Avatar
naw i had to fix the check engine light so i could retune i had it on 4 lbs but fixed a vac leak and now its at around 2 or 3lbs going to retune at around 8 or 9lbs to get 300hp
Old Feb 14, 2012 | 06:17 AM
fcm's Avatar
fcm
Old Fart
A solid CEL would indicate a bad ECU/ECM. 94
91DA951
Sep 8, 2007 11:17 PM
s2kc's
Mar 12, 2005 08:22 AM
scsheong
Nov 22, 2004 10:22 AM
wadafa
11
Oct 3, 2002 03:49 PM
