Climate control unit interchangable?
Old Jan 17, 2012 | 06:07 PM
Silver93t's Avatar
Default Climate control unit interchangable?
I need a climate control unit for my 88 CRX. I see two different styles: One has a lever to select where the air blows. The other has push buttons. Are these interchangeable?
Old Jan 18, 2012 | 03:59 AM
zrickety's Avatar
Default Re: Climate control unit interchangable?
The levers are for the civic hatch/sedan. You'll need to swap all the stuff under the dash to use it as the crx has electric controls. There are also some write-ups for using accord or EK climate controls, which might be a little easier.
Old Jan 18, 2012 | 06:42 PM
Silver93t's Avatar
Looks like its just easier to get the proper part. Thanks.
Old Jan 19, 2012 | 05:53 AM
krh0003's Avatar
Good luck. If you find a set of heater controls that aren't cracked you'd be extremely lucky. Try swapping to other controls like suggested above, at least then you'll have replacement options in the future.
Old Jan 19, 2012 | 08:23 AM
zrickety's Avatar
You can still buy new crx controls for $300
Old Jan 19, 2012 | 08:57 AM
jlk16188's Avatar
i swapped the civic controls into my crx. You have to swap the heater core out too. its easy. The worst part about it is taking the dash out and then wiring the lights in the civic control to work with the crx harness
GPC91
Aug 9, 2012 11:09 AM
m2theizzy
Aug 4, 2010 07:02 AM
KDvtec5757
May 19, 2009 07:20 PM
zachvirus
Dec 4, 2008 11:01 AM
miahmouse
Mar 7, 2003 01:13 PM
