Good deal on Brembo blanks from Tirerack
Old Jan 17, 2012 | 05:04 PM
TypeRod's Avatar
Default Good deal on Brembo blanks from Tirerack
Whats up HT! Just thought I throw this out there, just ordered new Brembo blanks for my Type R. Very good deal from TireRack. Get some if you need, shoot even if you dont need some, its a damn good deal, IMO. But its $48 for each front rotor and $40 for each back rotor.
Last edited by TypeRod; Jan 17, 2012 at 05:17 PM. Reason: fixed the small screen cap to be readable
Old Jan 17, 2012 | 06:09 PM
94rs-turbo's Avatar
Default Re: Good deal on Brembo blanks from Tirerack
not bad but I personaly recommend and use
Centric Plain 120 Series Rotors
cheaper, same great quality, and center prepainted so wont rust
Old Jan 17, 2012 | 10:27 PM
FULLYBUILT2.0's Avatar
Deal!!!
Old Jan 18, 2012 | 02:02 AM
TypeRod's Avatar
ive never heard of centric before, until i saw them on tirerack's site. My itr is 14 yrs old now, with 200,000+ miles and only on its 2nd set of pads and rotors, both OEM sets. I heard good things bout brembo blanks, so i thought i would give them a shot w. A set of hawk pads. I'll keep centric in mind. Thanks for the vouch about centric.
Old Jan 18, 2012 | 02:05 AM
TypeRod's Avatar
Originally Posted by FULLYBUILT2.0
Deal!!!
the quote in your sig made me weak. Lol
Old Jan 18, 2012 | 05:37 AM
94eg!'s Avatar
#1 Super Guy
Loved
Centric is the same company as both Stoptech and Powerslot. They make excellent stuff. I would actually put their premium rotors above Brembo blanks. The entire face of the rotor is machined, and all surfaces (except the friction surface) come e-coated (not just painted). Very high quality. They also sell MANY different compounds of brake pads. I'm using the Stoptech compound and premium rotors on my 10.3" EX brake swap on my 94 CX. The fit and finish is perfect. The pads are aggressive and rated up to 1200*f. The best part is there are SOOOO many Centric distributors in the US, that the parts can be had for a steal. Most of the dealers out there have coupons too (search google). I did a friends Toyota rav-4 for $108 in parts shipped with premium rotors and Posi-Quite ceramic pads (and caliper hardware). Best deals on Centric caliper hardware is usually on ebay.
They also sell re-manufactured calipers, master cylinders, pistons, caliper rebuild kits, etc... You can get like-new Brembos from the 04-08 TL for like $130 each (plus core).
http://www.google.com/search?rlz=1C1...w=1501&bih=896
The best part is that their website makes it really easy to find and cross-reference parts. Brembo's website is all but useless. I hate that. Especially when they come out with new part numbers for rotors every time they change one little thing.
http://extranet.soleniuminc.com/centricparts/
Old Jan 18, 2012 | 12:49 PM
TypeRod's Avatar
good stuff. Thanks for the info! I also got a set of hawk hps pads, never used them before. May return them, saw youtube vids about squealing. Has anyone used these pads before or know of somsone who has? Pls let me know the good and bad. Thanks!
Old Jan 18, 2012 | 01:42 PM
94rs-turbo's Avatar
I have hawk HPS pads on my 07 tsx with centric rotors, they never squeak on my car. brake dust isnt bad. they stop well(better than stock). Can be used for light track/ street use
Old Jan 18, 2012 | 02:11 PM
94rs-turbo's Avatar
Old Jan 18, 2012 | 02:54 PM
Keilani's Avatar
What would be the ideal replacement pads and rotors for a 00 ITR?
Just a weekend car and rare track car.
I was looking at EBC but it seems like there is better options,
Any suggestions would be great, thanks guys.
Old Jan 18, 2012 | 03:27 PM
TypeRod's Avatar
Im glad to hear it. Do you do the "bed in" procedure that Hawk recommends? If you did, do you need to do it as many times as they say? I dont have any roads long enough or empty enough around me to do it! lol!
Old Jan 18, 2012 | 03:34 PM
TypeRod's Avatar
Hey Keilani, all I've ever had on my R was OEM, and its just a daily driver, no track use at all. Might want to look into stoptech and powerslot. good luck!
Old Jan 18, 2012 | 06:03 PM
94rs-turbo's Avatar
you dont need much room, 0-30mph if that. if you cant go strait to 50 feet you live in a windy place lol much be fun driving the R there
Old Jan 18, 2012 | 07:51 PM
1998GsRIntegra's Avatar
Hawk HPS pads here as well and no squeaking at all. I did my(modified version of AP racing's burnishing process) bed-in procedure on them. You really want to try to get a transfer layer of pad material onto the rotor. Pads grab much better and the car stops much better overall. When the face of your rotors has a darker blueish color and they are no longer showing shiny silver through, you are done bedding in the pads. You will have to repeat the bed-in process as the transfer layer will wear off over time.
Old Jan 19, 2012 | 06:39 AM
TypeRod's Avatar
lol. I wasnt thinking right, i had seen a vid where a guy was bedding in new pads and he must have repeated it 8-9 times, starting bout 45-50 mph down to 10-5mph. He used up quite a bit of road, so i was like man i dont have any roads that long to do that quick enough w/o traffic and not having to turn around. Lol
Old Jan 19, 2012 | 06:52 AM
94rs-turbo's Avatar
45-50mph is a bit extreme IMO
Old Jan 19, 2012 | 06:59 AM
TypeRod's Avatar
thanks for your input about your hps pads. I think ill keep them and give them a try. I have to replace the rotors and pads on my 07 tahoe, if i like them on the R, ill get them for my Tahoe! I love ordering parts! Lol
Old Jan 19, 2012 | 07:07 AM
TypeRod's Avatar
the hawk pad procedure says 6-10 times, moderate pedal pressure, 30-35mph down to 5mph, then 2-3 hardstops w/o kicking in abs, 45-40mph down to 5 mph. Then park the car and release brakes right away and let them cool off. I wonder if 6-10x is really necessary.
Old Jan 19, 2012 | 11:32 AM
Salami's Avatar
The Centrics can be found even cheaper. Autoanything.com had them for only a few dollars cheaper than Tire Rack but does not charge for shipping. They are also the Premium rotors instead of the cheaper versions Tire Rack is selling. If you subscribe to their e-mail alerts they run some what regular 15% off sales. It should get you a complete set of rotors for ~$150 shipped.
Old Jan 19, 2012 | 11:58 AM
94eg!'s Avatar
#1 Super Guy
Loved
Originally Posted by Salami
The Centrics can be found even cheaper. Autoanything.com had them for only a few dollars cheaper than Tire Rack but does not charge for shipping. If you subscribe to their e-mail alerts they run some what regular 15% off sales. It should get you a complete set of rotors for ~$150 shipped.
$117 shipped for all 4 Premium-rotors with -10% coupon code "Centric" on Autopartsnetwork.com. I've ordered my Centric rotors and Stoptech pads from them and they were pretty good. Nice guy on the phone too checked stock for me and even called me back. Got to me in a week with free shipping (New York to Nevada).
BTW: Sometimes their coupon codes work on items other than what they say they work on. Last time I used a 15% off coupon for Timken products and it worked on my entire cart (Centric, Stoptech & NTN). Check google for better codes.
Another good place for Centric stuff is StockwiseAuto.com. They don't have front rotors in stock right now though. But you can find coupons for them on google as well. Last one I used was 10% off on anything. Their prices are usually lower than everyone, but they don't have free shipping.
Old Jan 19, 2012 | 12:17 PM
vtecvoodoo's Avatar
Future Texas Boy
good info brosef
Old Jan 19, 2012 | 12:43 PM
Salami's Avatar
Nice find! Where did you find the coupon code?
Just realized that is the coupon code. Sweet!
Old Jan 19, 2012 | 01:26 PM
94eg!'s Avatar
#1 Super Guy
Loved
lol....They always have coupons on their "Product Specials" page: http://www.autopartsnetwork.com/product_specials.html
Sometimes they have already expired, but they are still on their page. You may be able to call and see if they will honor it, but I don't know. The ones on there now are good till the end of the month.
Old Jan 19, 2012 | 01:29 PM
94eg!'s Avatar
#1 Super Guy
Loved
Originally Posted by vtecvoodoo
good info brosef
Thanks. I've turned into a cheapskate lately, as I have a wife, 2 kids, and 4 cars to take care of...
BTW: The coupon code "BedRug" works for the rotors too and it's good for -12%. Takes off another $3... lol
Old Jan 19, 2012 | 01:31 PM
vtecvoodoo's Avatar
Future Texas Boy
Got you beat...3 kids, wife, house and 4 cars.
