sticking throtle
Old Jan 17, 2012 | 03:17 PM
wchowc's Avatar
Default sticking throtle
does anyone else have an issue with sticking throttle below 3k or 4k rpm? maybe it is my intake manifold? Picked it up used and oversized of some sort. Does it just need some carb cleaner? or could it be a computer issue?
Old Jan 17, 2012 | 06:40 PM
jdmef69's Avatar
Default Re: sticking throtle
Check your throttle cable. Spray it with wd40 might be sticky. Clean the butter fly valve on the throttle body with car cleaner.
Old Jan 17, 2012 | 07:01 PM
acmoc's Avatar
check your TB cable and spray wd40 on the spring area.
the cable should have play. The cable is not what is suppose to hold it open for it to idle at 750ish although it does play a role
the screw on the TB plate should hold the plate open
Team PHATBOYZ
Jun 17, 2010 01:56 PM
NAallthewayEM1
12
Aug 1, 2009 08:41 PM
theresyourproblem
Oct 4, 2007 09:28 AM
rtpassini
Aug 1, 2004 12:31 AM
blunty
Apr 22, 2002 07:51 AM
