DPFI to MPFI. what to do???
Old Oct 8, 2002 | 06:15 PM
ponchdriver16's Avatar
Default DPFI to MPFI. what to do???
I got the d15b2 engine and wanna swap from DPFI to MPFI, will just switching manifolds do it, or do i have to set up wires for the injectors, and if so, how do i do it. lemme know if ya can help. thanks
Old Oct 8, 2002 | 06:21 PM
excitid's Avatar
Default Re: DPFI to MPFI. what to do??? (ponchdriver16)
I'll give you the answer there gonna give do a search.
Old Oct 8, 2002 | 07:35 PM
Losrocket_'s Avatar
Default Re: DPFI to MPFI. what to do??? (excitid)
Heres from zcivicz. This is from a thread a while ago. Good info!
DPFI TO MPFI CONVERSION
complete intake manifold (TB, fuel rail, injectors, all sensors!)
injector resistor
88-91 Si ecu
88-91 Si distributor
and an si coolant hose to connect the manifold and the block u can use ur stock and cut it if ur cheap
its pretty easy! drain the raidiator and all then take off the intake manifold and put the si intake manifold on and rewire everything. dissconect all the plugs from all the sensors and the injectors make sure u diconnect the coolant lines from the intake and there is one bolt that holds the manifold to the block underneath u wont see it unless u know about it
In order to convert your dual point injection DX to multi-point injection you will need 4 injector plugs, an injector resistor box, extra wire, and electrical tape(heat shrink is best).Also, when doing this conversion I would highly recommend soldering all connections and heat shrinking them. It is good to have an extra multi-point injection engine harness laying around to take plugs off of(injector plugs, injector resistor box plug, and distributor plug u can use ur stock dist plug if u cut one off another dx dist and use it to plug in but ull need a 2 wire plug for the ca sensor).
Pins B10 and B12 are empty. Unused pins can be taken from B2 or B11. Sometimes there is a unused wire at B12.
Cut orange and white wires off at C1 and C2 and connect them to wires added at B10 and B12. Orange-B10. White-B12. Leave enough wire for next step.
Run wires from C1 and C2 on the ecu into the engine compartment. Label these wires for later use.
Cut wires at A3 and A7 leave excess for later use. Run these wires into the engine bay and label them to be used later on .
Under the Hood
TPS and EACV plugs are too short and must be extended.
Be sure to switch green/white and yellow/white wires on TPS since the dx turns the opposite way.
Injectors and injector resistor box
Connect the yellow/black wires from the two DX injector harnesses and run it to the yellow/black wire on the injector resistor box.
Connect the yellow wire from the DX injector to the #1 injector (brown wire).
Connect the red wire from the DX injector and run it to the #3 injector (blue wire).
Connect the A3 wire to the #2 injector (red wire).
Connect the A7 wire to the #4 injector (yellow wire).
Connect the 4 red/black wires from injector resistor box to each injector.
Cylinder position sensor
Connect C1 to blue/green wire on cylinder position sensor plug.
Connect C2 to blue/yellow wire on cylinder position sensor plug
the rest of the wires are color matched. dx to the si wires
This was not done by me. All credit is due to zcivicz. Hope this helps.
Old Oct 8, 2002 | 09:01 PM
Louie B.'s Avatar
another scorce of info:
http://hybrid2.honda-perf.org/tech/4gdxtozc.html
the Si manifold is pretty much the same deal as the ZC mani
And definately use the search button on this site, there are a bunch of old posts on this board from people who ran into problems (myself included) Learn from our mistakes!!!
the swap is definately worth it!!!
[Modified by thumpu77, 10:04 PM 10/8/2002]
Old Oct 9, 2002 | 11:02 PM
No More Civic's Avatar
Default Re: DPFI to MPFI. what to do??? (thumpu77)
I would suggsest ordering the back issue of Sport Compact Car where they did it. It's nice since it has wiring diagrams and has complete instructions on doind it. It's The June 2002 issue, volume 14, no. 06. Hope that helps. I knw those are the instructions I'm going to be using when I finally get around to doing mine. Right now I'm getting ready to put in a new clutch and a custom built Si tranny I got from a freind who's starting a job for Honda R&D next week.
Old Oct 10, 2002 | 04:03 AM
Stupid Ass's Avatar
Default Re: DPFI to MPFI. what to do??? (SlowCivicDX)
From what I saw, the article SCC did was totally wrong and I heard alot of people were complaining to them about having wrong pinouts, etc...
Old Oct 10, 2002 | 06:14 AM
zcivicz's Avatar
Default Re: DPFI to MPFI. what to do??? (Losrockeeto)
although i would love to take the credit, i'm not gonna. i didn't write that up to be honest.....some other guy wrote that up and i just edited a few spelling mistakes.
thanks anyway.
and one more thing. you don't have to extend the TPS and EACV plugs. just take the plastic loom off and plug em in!
miguey310
Feb 25, 2009 06:04 PM
SPOON_EG6
Dec 9, 2002 04:03 PM
crxtremes
Oct 12, 2002 11:24 PM
juice-it
Jul 16, 2002 11:48 AM
Mugen Dom
Jun 16, 2002 02:47 PM
