is my motor going to be okay?
Old Jan 16, 2012 | 08:02 PM
EF8DayDreamer's Avatar
Default is my motor going to be okay?
I left my motor out with a tarp over it. The tarp blew off and it got snowed on for about 30 minutes. I dried what i seen was wet, wires valve cover intake manifold dizzy, and put a towel the tarp and a garbage bag over it.
Old Jan 16, 2012 | 08:41 PM
Kocho333's Avatar
Default Re: is my motor going to be okay?
did snow get inside the motor? u shouldve plugged all ports with rags or plastic.
im assuming this is a spare motor? ive seen motors left out for seasons, installed and started with poofs of smoke. im sure ull be fine.
i power washed one engine, water got into spark ports, couldnt dry it all up, pulled plugs and crank, watch the water shoot out like little fountains. plugs back in, started no prb...
they do that with roll overs, oil gets into the cylinders, its the only easy way to compress out anything that doesnt ignite.
Old Jan 16, 2012 | 08:49 PM
Okay thanks. I was worried about it.
Old Jan 16, 2012 | 08:53 PM
Kocho333's Avatar
yea give it fresh oil when u install, turn the crank with a ratchet a few turns to move some oil around and u should be fine.
Old Jan 18, 2012 | 08:49 PM
okay. thanks man. will do.
Old Jan 18, 2012 | 09:01 PM
Dc4LsTeG's Avatar
EK9
Make sure there's no water in your spark plug holes
Old Jan 18, 2012 | 10:12 PM
DirtyDA9's Avatar
Were the spark plugs in? And were the intake and exhaust manifolds on? You will be fine either way, just pour a little bit of oil in the cylinders before you turn the engine over.
2hondas_noluck
May 18, 2011 09:13 AM
sw96
14
Nov 8, 2009 11:05 PM
BoM
Aug 13, 2001 10:54 PM
wuhungsixxx
Jul 17, 2001 12:17 PM
