Intermittent idle issue after timing belt change
Old Jan 16, 2012 | 04:43 PM
Scotty Dosent Know's Avatar
Default Intermittent idle issue after timing belt change
This is on a B20. Changed the timing belt, water pump and tensioner. I do not believe timing is off. With white mark on crank pulley lined up you can drop a punch through the cam caps into the cams. + I did not move the cams or crank really during the change.
Car starts up cold and seems to idles fine. Every once in a while it could maybe idle a little rough......maybe just low. After I have been driving it for a while if I turn the car off and say go into a store for a while some times when I come back out and start the car up it fires up but idles low for a couple seconds then goes to a normal idle. Almost like idle is to low or its missing??
If I turn the car off and re start it, it does not do it. It will start up and idle just fine.
I cleaned the engine bay right after the belt change but I have driven it about 600 miles since then so nothing is damp. I have also pulled all electrical plugs apart and blown them out with compressed air. Installed new spark plugs. Removed throttle body and cleaned it along with IACV. Cleaned grounds. Pulled dist. cap to check for moisture.
Any ideas as to what this could be would help alot! It did not do this before the belt change and engine bay cleaning
Old Jan 16, 2012 | 05:33 PM
el crapitan's Avatar
Default Re: Intermittent idle issue after timing belt change
what i'd probably do is check ignition timing.
if that's bang on, check for vacuum leaks with a can of quick start
Old Jan 16, 2012 | 06:57 PM
I have had a timing light on it and it seems to be just fine. Jumpered the connector and set timing.
Could needing a valve adjustment cause this problem? They are kind of noisy. Car has 260K and I have put 60K of those on my self with no adjustment so who knows when it was done last.
Its just weird that it only idles low for a couple seconds after its warm........sometimes
Old Jan 16, 2012 | 07:21 PM
is this a b20z? or b20b?
do the valve lash adjustment regardless. b20's are apparently notorious for burning exhaust valves for that reason.
it sounds a bit synonymous with a collapsed/collapsing vac line. since it mostly occurs warm. have a good close look and feel at all your vac lines and see if you can find any that look like they're collapsing. not a guarantee, but a possibility.
check for leaks as well with the quick start
Old Jan 16, 2012 | 07:46 PM
I will check vac lines tomorrow and see how it goes. I have to buy or make a tool to adjust the valves.
I believe it is a B20b, the car is a 98 CR-V. Posted in here because I'm sure there is a lot more traffic than in the CRV section lol
Old Jan 16, 2012 | 07:51 PM
hah! i have a 98 crv as well. i'm in that section all the time lol
Old Jan 16, 2012 | 08:23 PM
Solster's Avatar
cleaned out the engine bay with degreaser and a hose i'll bet.
Try taking off the disty cap and getting the water out of there it should fix the problem.
if not check all the sparkplug tubs for water
Old Jan 16, 2012 | 08:36 PM
Nice! I love mine this is the first problem I have had with it. Water pump decided to die so I changed every thing out. Sucks when you try to fix it and it runs worse afterward lol
I have put about 600 miles on it since the degrease lol Have removed dizzy cap and its dry in there I have also replaced the plugs and had the valve cover off to double check timing since then.
Water down in the plug holes is first thing I thought about haha
Old Jan 17, 2012 | 04:31 AM
try checking for codes as well. never know. you may get lucky and it'll throw you a bone
Old Jan 18, 2012 | 03:43 AM
Solster's Avatar
recheck all you electrical connectors are connected and that you dont have water in them
Tarlacon
Nov 9, 2008 10:40 PM
ProjektR
Jul 25, 2006 10:09 AM
Eg_Ryan
Jun 13, 2006 06:44 PM
MoBlack
Nov 21, 2005 06:43 PM
llevity
Jul 12, 2005 02:39 PM
