Denso, Injector Dynamics Which I Use on Budget???!!!
Ok so im wanting to run E85 on my set up.. I have ID 1000cc and if i use e85 ill run out of injector so i need to bump up to 2000cc. Ive seen some denso II that are like $500 and id 2000cc for $900. Here some info on my build
84mm 9.7.1
Port n polished b16 head
Victor X
Precision6265
Skunk2 Pro1 cams (cams Degrees)
3" downpipe
3" intake
2.5 outlet
46mm wastegate
twin pumps
Its fully built.. Best time was 10.6@146mph with a 1.8 60ft psi was around 18-24 lbs keept boost creepin. (gettin that fixed) Goal is i want to hit 9's level at 26-28psi. I was told E85 will be alot safer for my motor since i have a heavy foot so wut u guys recommend???
84mm 9.7.1
Victor X
Precision6265
3" downpipe
3" intake
2.5 outlet
46mm wastegate
twin pumps
Have you check out Bisimoto new line of High Imped. custom injectors? We have done testing with our 2000cc on our turbo 2012 Civic Si K24 which made 1004whp on VP gas E85R and Bisimoto Wagovan 700+whp on pump gas with an AEM water/meth kit. Bisimoto Fuel Injectors
really? so you do what Injector dynamics does also you just match sets? IF that's not custom i don't know what is!
Go get some ID2000 or maybe some deatschwerks injectors which are cheaper then all these. Don't let these companys tell you they "custom" make these injectors they just get say a Denso injector and then just make sure they all flow the same. No real R&D on the part of bisimoto or ID or deatschwerks
Ooo juilo, you crack me up sometimes giving me all this info from your site, what tests has bisimoto done? Who makes these injectors? Care to explain how a id2000 can't flow c16 when lots of race teams use them? Not just in hondas but other cars as well. Don't come in here giving false information and not being able to back it up.
I tried running Q16 through ID2000's, and they basically swell closed after running for ~20 minutes.
I would say any "testing" of Q16 through an injector resulted in any favorable results... it would be fairly proven that they are functioning with Q16.
I am only interested in the answer to ^^ question. I think most people know these companies are modifying Denso/boschs to flow specific cc's then labeling them their own. cant wait till another company just decides to do the same for $400 2200cc injectors this way the consumer wins as competition drives down market price.
I am not going to waste my time even saying anything about Bisimoto. Neither one of these companies make an injector. Like mentioned above they take a bosch injector and modify it to flow more and call it their injector. They are all bullshit. I would just buy the 2000cc bosch injectors from ID and sell the 1000cc injectors.
Or try these. Come out to about 720+ shipping.
http://www.ebay.com/itm/FIC-2000cc-H...item483c7305d8
is the picture in that link the actually injector that flows 2000cc?
I loled. One thing I cannot stand is when a company comes into a conversation just to say use our **** because it is tested and proven to work 5 billion times better than everyone else. ID injectors are like the new standard of what is a top notch technically speaking off the shelf because they are already matched for you.
Why cheap out on the most important part of your vehicle? The fuel system...
This isn't a shift **** or headlight bulb your talking about...
Spend the money on quality, proven parts & never think twice.
Ams injectors! they actually use injector dynamics injectors they modify and make larger cc sizes available looking too get myself a set of 1600cc injectors from them now
Also Mods I call someone a scum bag and you delete it from my post? Whats with that? Because it was Bisi?
Can someone please start a thread and invite all of these sellers to get their 1000cc & 2000cc & 2200cc injectors to be tested on a side by side, equal base pressure & voltage comparison? like the guy said ^^ these are all modified stock injectors
ID
FIC
FIVEO MOTORSPORTS
BISIMOTO
EFI WIZARD
AEM
And any other company selling injectors modeled after the Bosch EV14 style or similar. I think its about time to condense all this rumored information & get some facts identified and point out the Pros & Cons of each injector, and which application would be suited based on actual performance. Let the product speak for itself, and the company who performs the best, as well as the consumer, will both benefit from having accurate information.
Any takers vendors?
ID
FIC
FIVEO MOTORSPORTS
BISIMOTO
EFI WIZARD
AEM
Any takers vendors?
I personally thought what you said was a bit "harsh" on Bisi. But then again i don't know whats fully been going on between you guys and him/them and if it could be justified.
fink is the poster boy for bisimoto ripping people off, hundreds of dollars spent on a custom bisi header that was supposed to be stainless and ceramic coated, made less power then a ebay replica and is rusting right through. calling bisi a scumbag is being nice.
