Removing Sedan Center Vents
Old Jan 16, 2012 | 02:23 PM
gclambert's Avatar
Default Removing Sedan Center Vents
Hello, I'm new to this forum and I am looking for some sound advice. I am a proud owner of a '91 civic sedan, and I am in the process of mending a few functionality issues.
First off, my center console vents. Im not sure when it happened, but some how the dial which controls the horizontal direction or channeling of the air flow has some how been pushed inward, and I cannot seem to fix this issue without removing the vent cover itself. Leading me to my first question..
How do I remove the cover safely without damaging it?
Old Jan 16, 2012 | 03:26 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: A newbie that needs some advice
Pry the top out and remove it...
Old Jan 16, 2012 | 06:59 PM
gclambert's Avatar
i understand I have to pry it, I also understand how easy it is to break. Should I start prying it off from the top center, or near the corners?
Old Jan 17, 2012 | 03:59 AM
DO IT ON ALL FOURS
If you can the middle of both vents but then again it's more controllable to start from one corner and work your way over. If you have strong enough hands just grab the bezel lip and pull it out.
Old Jan 17, 2012 | 04:35 AM
CRX Toad's Avatar
Default Re: Removing Sedan Center Vents
Get the proper plastic ply tools and do it from there they are around $10-$15 and they will not damage the dash or the vent.
graham_ott
Honda Civic (2001 - 2005)
Jun 29, 2015 10:12 AM
evilcivilian
Feb 12, 2008 04:09 PM
mpxs20
Jul 18, 2005 02:52 PM
TypeRPinoY
Nov 28, 2002 07:57 PM
