96 accord, still no tail lights or panel lights
Old Jan 16, 2012 | 01:06 PM
Rowdy Rod's Avatar
Default 96 accord, still no tail lights or panel lights
I just replaced the headlamp switch in the steering column but still have no tail lamps, panel lamps, license plate lamp, side marker lights, or warning buzzers. The electrical diagrams do not show the in dash dimmer button for dash lights so I cannot tell how it works with the rest of them. What can be the problem here? Need help fast.
Old Jan 16, 2012 | 01:08 PM
Dioxine's Avatar
Default Re: 96 accord, still no tail lights or panel lights
Did you check all fuses including the ones under the dash and the ones under the hood.
Old Jan 16, 2012 | 02:36 PM
Rowdy Rod's Avatar
Yes, I see no blown fuses in the left kick panel, or under the hood.
Old Jan 16, 2012 | 02:54 PM
Lost Again's Avatar
Ground the red wire of the dimmer with the headlights.......what happens. Do you have 12v to the RED/BLK wire of the dimmer with the lights on?
Old Jan 16, 2012 | 03:40 PM
Rowdy Rod's Avatar
I just found the problem. The underhood #32 15 amp fuse for lights was in the "spare" position. This happened after we cleaned out the IACV and tried to reset the ECU by pulling the fuse. The wrong fuse was pulled out and put back in the empty spot. Bone head mistake.
Thanks for the help guys.
bearstitch
Apr 24, 2016 07:05 PM
slammedbbs
May 7, 2011 02:30 AM
slammed em1
Jan 23, 2010 09:26 PM
92honda92
Sep 27, 2007 07:48 AM
xxx
Oct 31, 2005 06:57 PM
