Integra leaking gas from charcol canister
Old Jan 16, 2012 | 12:21 PM
fernando.'s Avatar
Default Integra leaking gas from charcol canister
Hey guys, so my beater started leaking gas from the drain/bottom of the charcol canister after I filled the tank up to the top last night. Only had the car on the road for two weeks so I've only filled it up to about half, and last night when I filled it to the top for the first time it started pissing out of the bottom of the charcol casister BUT when I took off the gas cap, it stopped leaking.
So my question now is, since the charcol canister got saturated with fuel, will I have to replace it to do an emissions test?
EDIT: Now the car is bogging and cutting in and out.
Old Jan 16, 2012 | 03:04 PM
bryan24207's Avatar
Default Re: Integra leaking gas from charcol canister
bc with the cap on it seals in the pressure forcing out the gas, when its off the pressure is released so it doesnt force it out your canister
Old Jan 16, 2012 | 03:18 PM
fernando.'s Avatar
Should I keep the cap off untill I use up some of the fuel?
Also, could anything else be the cause of the fuel coming out the canister?
Old Jan 16, 2012 | 03:28 PM
DirtyDA9's Avatar
That's wierd, the canister is just for fuel vapors, to keep pressure from building up in the tank, actaul gas should no be coming out of there. Remove the charcoal canister and see if the gas pours out of the hose from the tank (the one that connected to the canister)
Old Jan 16, 2012 | 05:28 PM
fernando.'s Avatar
^ Well yeah, if you overfilled or 'top off' the tank you run the risk of having the evap system suck the fuel and not vapours.
Since the charcol canister got saturated with fuel, will I have to replace it to do an emissions test?
Old Jan 16, 2012 | 09:35 PM
00ekcoupe's Avatar
Charcoal canister issue should set off the CEL and yes that will be an issue at emissions. How is it leaking from the bottom? Is it cracked or is there some sort of overflow drain or something (that I never saw)?
Mine was cracked on the bottom, no idea how, bought the car like that. It literally had a hole like an inch and half in diameter. It leaked some sort of grease like substance onto whatever was below it, like my axle. Anyhow, I just replaced mine with another OEM one that some guy was parting out. Try to locate one locally or on CL. They are pretty expensive from dealer.. IIRC, around $150+. Hope that helps!
Old Jan 17, 2012 | 05:16 AM
ZOOYOST's Avatar
i had this issue on my ef beater, i kept it half tank :p
Old Jan 17, 2012 | 06:59 AM
fernando.'s Avatar
Its leaking out of the bottom, which leads to a fresh air intake for the canister.
Now I have an even bigger problem, the car started bogging and cutting in and out quite bad.
Old Jan 17, 2012 | 09:45 AM
00ekcoupe's Avatar
I've heard of some people removing it completely and the car should run fine still. I def suggest just replacing it. Sounds possible you might have other issues?
Old Jan 17, 2012 | 10:19 AM
DirtyDA9's Avatar
The fuel is probably be sucked into the intake from the canister, cuasing it to bog. Your best bet is to just remove the canister, but then you will not pass visual inspection.
Old Jan 17, 2012 | 10:22 AM
Solster's Avatar
if the charcol get wet it breaks down and the motor can suck it into the intake and thats never good also the car should have a VENTED gas cap if i remember use of a NON-VENTED cap is the cuase of this problem.
Old Jan 17, 2012 | 02:28 PM
TheRealTegger's Avatar
Sounds like the hoses are connected wrongly. What year Integra?
Old Jan 17, 2012 | 03:16 PM
fernando.'s Avatar
Hose are connected correctly, the car ran fine for past two weeks I've owned it. The first time I filled up the tank to the top this happened.
Old Jan 17, 2012 | 03:34 PM
Care to answer my question?
Old Jan 17, 2012 | 04:19 PM
fernando.'s Avatar
1996.
Old Jan 17, 2012 | 04:57 PM
fernando.'s Avatar
Apparently there's a two-way check valve ontop of the tank that controls fluid flow, anyone have a part number or a diagram for this?
Old Jan 17, 2012 | 08:34 PM
el crapitan's Avatar
yes, there should be a liquid/vapor separator. this keeps liquid fuel from entering the canister.
have you checked the codes? a pressure/vacuum related issue will set a code
check those first and report back
Old Jan 18, 2012 | 03:40 AM
Solster's Avatar
part number is 17372-SR3-010 found it at
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Old Jan 18, 2012 | 06:21 AM
fernando.'s Avatar
Like I said in my other thread, I have no codes. That two-way check valve might be bad in my car which is why I'm getting gas in the EVAP system.
Thanks man!
Old Jan 18, 2012 | 06:31 PM
typically, the evap system only throws a code if there is a leak. i don't think a bad 2 way valve will throw one.
it is, however, the only way that liquid fuel could enter the canister.
i doubt there are 2 issues. if you suspect bad gas, disconnect the purge valve, see if the bogging goes away. if it does, it's because the purge valve is allowing raw fuel into the intake. which it's going to do if there is raw fuel in the canister. which there never should be.
so basically, both problems are likely due to an issue with the 2 way valve
Old Jan 18, 2012 | 06:38 PM
fernando.'s Avatar
The bogging randomly stopped, the car doesn't leak gas and drives amazing again.
Looks like it's that two-way check valve that's to blame, so can either A replace it, or B not fill up to a full tank, lolol.
Old Jan 18, 2012 | 06:43 PM
DirtyDA9's Avatar
^^ Probably because the fuel level has gone down. Doesn't mean the problem is gone. Replace the check valve.
Old Jan 18, 2012 | 06:50 PM
technically, it's a 2 way valve. not a check valve
be aware though that because the canister was filled with liquid, some of the pellets may have been expelled and could clog up the vent tubes. just watch out for that
Old Jan 20, 2012 | 02:23 PM
fernando.'s Avatar
It's a beater, if I don't have to spend the money I won't. Lol. Car runs A+ now and everything is back to normal, I just simply won't "top off" when I fill the tank, that's all.
Yeah I've pulled off vacuum lines to see if any pellets/deposits have plugged anything and it all looks ok. Going to replace the canister with another unit tomorrow.
mariner133
Aug 8, 2018 01:01 PM
TheDonut
Mar 31, 2011 04:53 PM
93_db2
Apr 12, 2008 04:11 AM
MidwestCivic
13
Jul 17, 2007 05:31 PM
Turbo Powa
Oct 1, 2002 09:09 PM
