Creamy color oil
Old Jan 16, 2012 | 09:17 AM
f@sth@tch89's Avatar
Default Creamy color oil
I took off the valve cover and I saw a creamy substance all over. My car(race car) is kept in the garage. I hadn't fired it up in about a month. Im running torco oil. It is pretty stock and seeing that creamy like substance freaked me out. Cause for concern? what is the cause? I was just put in there about 2 months ago.
Old Jan 16, 2012 | 09:32 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Creamy color oil
Is it also in the oil pan? Could just be condensation.
Old Jan 16, 2012 | 09:45 AM
turbohatch96y7's Avatar
Creamy means a bad headgasket. Drop your oil if it looks like milk time to change your head gasket.
Old Jan 16, 2012 | 10:44 AM
Let me check the oil pan. I just ran the car at IFO this past weekend. no problems. I will drop the pan and check. The gasket is new. A honda headgasket at that!
Old Jan 16, 2012 | 11:28 AM
HondaPartsHero's Avatar
Technical Hero
Not always
http://www.offroaders.com/tech/milky...er-oil-cap.htm
Old Jan 16, 2012 | 11:40 AM
If you drop your oil and you have nothing but milk than its most likely a head gasket. Moisture will devolp under the cap but if your oil is white than its more than moisture.
Old Jan 16, 2012 | 08:52 PM
Kocho333's Avatar
yeap, might be worth to change oil run it for few days and see out come(double check precaution before pull apart motor)... i agree with everyone else tho.
Old Jan 16, 2012 | 09:08 PM
West Werks's Avatar
What kind of fuel do you run?
Old Jan 17, 2012 | 09:21 AM
El chico's Avatar
did the car overhead last time that you drive it?
Old Jan 18, 2012 | 06:08 PM
91 octane w/ torco additive
Old Jan 18, 2012 | 06:11 PM
The head was milled a little and hot tanked and reassembled. The motor I bought from a guy off honda tech a while back. Block was in good condition when head was taken off.
Jon Petersen
25
Mar 2, 2019 08:11 PM
cletus11
Jan 14, 2012 12:49 PM
big-cat
Aug 8, 2009 05:05 AM
Kapetan
Oct 19, 2006 08:35 AM
Mattyg2
Aug 28, 2004 04:50 PM
