Skunk2 turbo cams install help
Old Oct 8, 2002 | 05:40 PM
realblazeracer's Avatar
Default Skunk2 turbo cams install help
Hey Everybody,
Does anybody know where I can find some install pics/instructions? I will be attempting to do a cam swap in preparation for a turbo. I have Skunk2 turbo cams, springs and retainers. Aside from basic tools are there any Honda/Acura specific tools I should use? Hopefully you guys will point me to website I can use???
Thanks in advance
Old Oct 8, 2002 | 05:44 PM
done's Avatar
Default Re: Skunk2 turbo cams install help (realblazeracer)
sorry cant help,
but .. you have the new skunk2 turbo cams, any specs on them???
Old Oct 8, 2002 | 08:49 PM
Default Re: Skunk2 turbo cams install help (Jordo)
I'm not sure if this what you are asking for? But here it is anyway.
INTAKE: Duration 1mm: 230 Degree LIFT: 0.385" (9.7mm)
EXHAUST Duration 1mm: 225 Degree LIFT: 0.350" (8.9mm)
Old Oct 8, 2002 | 09:20 PM
98itR484's Avatar
buy a tool that allows you to remove valve springs without taking off the head, helps a bunch and saves a lot of time. Also if you are planning on using this tool, be sure that you fill the chamber with air so the valve doesnt drop. thats just a summary..if you need more just pm me always glad to help
sherdog9
Aug 20, 2007 09:47 AM
s2kkk
Mar 7, 2005 09:14 PM
JDMsurf
Jun 8, 2004 01:26 PM
asianic415
Dec 7, 2003 08:46 AM
nerces
Feb 18, 2003 10:32 AM
