rear disc conversion
well im in the middle of converting to disc brakes and i went to put new trailing arms back on and realized the spot where toe bracket bolts up the nut droped down in frame and it is sealed pretty good has anyone else had this happen if so did u cut a hole or somthin to get to it? and does anyone have honda part numbers to replace the bolts for rear lcas, shocks and the toe brackets?
yeah you can make a small hole to access the broken bolt. if you notice, the whole area that the nut is welded inside of is spot welded to the frame so that portion that houses the nut housing is not structural
as far as part numbers, go to http://www.hondaautomotiveparts.com to look for the bolts. theyre generally the cheapest place online to order oem parts.
hope that helps
hope that helps
wade
Suspension & Brakes
May 25, 2006 12:18 PM
UK CIVIC B16A2
Jul 17, 2003 02:07 PM
