tps adjustment 97 civic w/obd1 h22a
Old Jan 15, 2012 | 12:13 PM
accord2civic2prelude's Avatar
Default tps adjustment 97 civic w/obd1 h22a
I had to replace my tps due to a cracked pin cover and eventually one of the pins breaking off. I replace it with a known good one. While trying to set it, i am getting readings of .41 at closed throttle and 1.45 at wot. I have read that you have to move the tps in order to get it right. but with a reading of 1.45 trying to adjust would throw the closed throttle off by a lot right?
Old Jan 15, 2012 | 12:14 PM
grumblemarc's Avatar
The Grumpiest
Default Re: tps adjustment 97 civic w/obd1 h22a
Have you tried it?
Old Jan 15, 2012 | 12:46 PM
yes just did at at closed im getting 0.76(too high) and wot is 4.5(which is where it needs to be)
Old Jan 15, 2012 | 12:55 PM
The Grumpiest
I know what's normal for a Civic but is that normal for a Prelude? Just asking for future reference.
Old Jan 15, 2012 | 02:23 PM
not too sure on the prelude subject. But i adjusted it a bit and got it to read 0.5 closed and 4.9 wot. is that ok or should it be exactly 4.5 at wot?
Chris Will
Oct 24, 2014 12:39 PM
Brownjd
Feb 2, 2011 03:57 PM
wax4183
Sep 22, 2010 08:50 AM
jstyl
Feb 27, 2010 08:01 PM
THC07
Feb 17, 2006 03:21 PM
