PLEASE HELP: Problem Starting 92EG
Old Jan 14, 2012 | 07:42 PM
bucknastty's Avatar
Default PLEASE HELP: Problem Starting 92EG
for some reason when i go to start my 92EG it doesn't want to start like it should. it usually starts on the second try but if I've been driving it hard then it wont start till about the fourth try. i have an MSD external coil. I've recently replace the starter, alternator and spark plugs. Don't know if any of that matters but just in case. thanks for reading any help will be appreciated. thank you
Old Jan 14, 2012 | 08:21 PM
Former User's Avatar
Default Re: PLEASE HELP: Problem Starting 92EG
Is this a no crank problem or a cranks but won't start problem?
Old Jan 15, 2012 | 09:19 AM
bucknastty's Avatar
when i turn the key and try to turn it on its trying to crank it just wont start you can hear it turning
Old Jan 15, 2012 | 11:49 AM
DirtyDA9's Avatar
Possiby a weak fuel pump, and bad check valve so it's not holding pressure in the fuel system.
Old Jan 15, 2012 | 12:49 PM
Listen for whether the fuel pump primes.
Check for spark at the plugs.
Check for CEL codes.
93daintegra
Sep 30, 2008 04:58 PM
cbrracer91586
May 19, 2007 04:31 PM
same ol' civic
Jun 5, 2005 07:29 AM
lazykiwi
Jan 16, 2005 08:44 AM
si00000
Nov 1, 2001 06:10 PM
