K20 EK first start header is glowing RED! Help
Old Jan 14, 2012 | 12:46 PM
Sp00nFed EM1's Avatar
Default K20 EK first start header is glowing RED! Help
Here's the rundown on the car:
Stock K20z3
97 Ek coupe
JDM ITR ecu (fuel pump grounded)
11.7:1 wiseco
Center feed fuel rail tucked with return off the regulator
Cylinder runners 2 and 3 were glowing red hot after only a few minutes. This was the second start up. First time I was off timing on the cam gears. Tried starting it quite a few times while it was off timing which leads me to believe that maybe I damaged some valves. Maybe I'm overreacting.
Here's a video of the first start followed by the second start where you can see the headers glowing red in those cylinders.
First - http://www.youtube.com/watch?v=NLZjJ...e_gdata_player
Second - http://www.youtube.com/watch?v=pBILe...e_gdata_player
Old Jan 14, 2012 | 03:07 PM
Default Re: K20 EK first start header is glowing RED! Help
Think I got it. I had the tps and map plugs switched. Would that do it? *Also now that I'm trying to adjust the tps I can only get as low as 1.5v at closed throttle and I'm at 5.10 at wot. *
Think I used an accord tps. Would that matter?
Old Jan 15, 2012 | 07:03 AM
Well I assumed the header heat issues were because I had the TPS and MAP switched. But how come I never got a code for either? And I also never got a code for crank angle which I thought I would if it was out of timing.
Old Jan 15, 2012 | 07:28 AM
Dioxine's Avatar
Generally no, switching the tps and map will not throw a code. When i had mine switched i never got a code. And how far out of time was it?
Old Jan 16, 2012 | 07:50 AM
JW racing's Avatar
Thin material headers usually glow after the motor has been running for a few. You should see mine on the dyno!
Old Apr 3, 2012 | 08:05 PM
Ek_David123's Avatar
I agree with dioxine
gp356
12
Jan 7, 2013 02:17 PM
Lan
Jan 2, 2013 06:45 AM
Sp00nFed EM1
Jan 16, 2012 06:31 AM
sikefcrx89
Feb 18, 2009 05:42 PM
