eg sedan -- installed skunk2 lower control arms and they are making noise
Old Jan 13, 2012 | 07:27 PM
Nick's SI's Avatar
Icon2 eg sedan -- installed skunk2 lower control arms and they are making noise
Im kinda new to this . i just put some skunk2 lower controle arms on my brothers sedan and the are making a noise . just wondering if thats normal
thanks for the help
Old Jan 13, 2012 | 07:43 PM
mmcd's Avatar
Default Re: eg sedan lower controle arms
what kinda noise?
Old Jan 17, 2012 | 06:08 PM
Nick's SI's Avatar
Default Re: eg sedan -- installed skunk2 lower control arms and they are making noise
like somthing rubbing
Old Jan 17, 2012 | 06:12 PM
grumblemarc's Avatar
The Grumpiest
Guess you need to get under the car and find out exactly what is rubbing. It's NOT normal. I have them on my coupe.
Old Jan 17, 2012 | 06:37 PM
mmcd's Avatar
^ lol I agree. Did you put them on the proper? As in did you tightin the bolts why it was on the ground or up in the air? there isnt much you can mess up with LCAS
Old Jan 17, 2012 | 06:43 PM
The Grumpiest
Did you preload the bushings?
Old Jan 17, 2012 | 07:57 PM
98civdx's Avatar
Master Detailer
Don't skunk2's run poly bushings? If so, you don't need to preload.
But, are you sure it's the lca's?
Old Jan 18, 2012 | 03:59 AM
The Grumpiest
No. Not poly. They looked like a hard rubber compound to me.
Old Jan 18, 2012 | 07:44 AM
black_eg92's Avatar
Skunk2 bushings are indeed poly
Low-deflection, polyurethane bushings act as bearings for quicker response and a more positive feel...
Old Jan 18, 2012 | 07:47 AM
black_eg92's Avatar
I have been through 2 sets of skunk2 control arms.. Make sure you lube them before installing even though they dont tell you to. The bushings dry out after a few years of abuse.
Old Jan 18, 2012 | 07:50 AM
The Grumpiest
So they are. I wasn't aware that poly bushings dried out.
But I did anyway. With the way these are designed I guess you don't need to. Whatever. Time will tell either way.
Old Jan 18, 2012 | 09:57 AM
98civdx's Avatar
Master Detailer
I was thinking they were. Poly bushings, don't really last that long. Unless you take good care of them.
I've seen poly bushings crumble after ~2 years use, but I have also seen them last 3-4+ easy when cared for.
A pro, I think, that you don't have to clock them.
I would definetly clean/lube the bushings, I don't care what Junk2 says.
94eh2
Mar 22, 2010 06:38 AM
hondasingapore
Suspension & Brakes
Oct 15, 2009 01:14 PM
dc-2_mike
Jun 2, 2009 05:34 PM
allricedout
50
Jul 20, 2008 05:50 PM
egvtec
Nov 3, 2007 06:31 PM
