15x6 with slight stretch
i have a eg hatch and im swapping my itr 5 lug on soon. looking to run the OEM itr rims. but looking for a very very slight stretch. just enough to help with any rubbing. im not slammed and not looking for the"hellaflush" look.
and ideas? would i be better going with a 15x7 rim with slight stretch?
car is a daily/weekend warrior autox.
thanks
since i do auto x this every so often, would the slight stretch be a bad idea?
i know it gives a slight less traction with the stretch, but is it alot if minimal?
i will be running 2-3 negative camber
thanks
First off, what exactly is a "slight stretch"? Either the tire is approved for the wheel size, or it isn't.
Second, threads about stretched tires aren't allowed in here.
You're running OEM DC2 IT-R wheels WITH negative camber? You won't need any stretch what so ever for that setup. Heck, even with 0 degrees of camber, you wouldn't need to run a stretched tire.
sounds good. i was talking to a old autox junky. hes a mazda miata guy. he was trying to tell me that a "slight stretch" would help for gripping and camber.
also didnt know u couldnt post bout stretched tires. my bad, should have read the sticky
thanks
thanks
Currently, I'm almost at the narrowest width wheel I can run for my tire setup (exact opposite of "stretching" a tire) and have been quite happy with the results, when compared to tires of a narrower section width.
Ej1SIR
14
Oct 7, 2009 01:27 PM
Mr. KDes
Nov 21, 2008 07:29 AM
dt98gsr
Mar 7, 2008 04:05 PM
