Engine code
its d16a6 if its usdm, to find it you can find the upper radiator hose inlet on the engine, and go down about 2-4 inches and to the left some, it should be a flat surface on the block, clean it off if you have to. It should be d16a6 if its a sohc and an Si
and is your tranny 5 spd? if it is then you've got an Si, for the most parrt. The std only had a 4 speed, as i understand it
[Modified by altoid, 8:50 PM 10/8/2002]
thanks for the help. I have a 4 spd tranny but i know that the dx has a 5 spd tranny just like the si. Is there a difference between the 2? What about the tranny number? Is there a number?
yes there is a difference between the dx and si tranny. The final drive gear is higher in the dx for better gas mileage. The si tranny is better for acceleration though.
[Modified by ZZZZZZZ, 5:07 PM 10/14/2002]
BlueRex1020
May 26, 2007 01:22 AM
youngwon22
Jun 20, 2004 11:01 PM
CrxSi707
May 25, 2004 08:56 AM
