97 Accord main relay issues?
Old Jan 12, 2012 | 09:02 PM
gogydm's Avatar
Default 97 Accord main relay issues?
Hey I have been having this clicking noise every time I try to crank the car. It does not start. There is a spark and the fuel pump works for sure. The injectors seem to not be opening. Does this look like a main relay issue or is it something else. There is a loud click that can be heard from under the dash (steering wheel area) and the Check Engine light illuminates and goes off in sync with the clicking. Thanks in advance!
http://www.youtube.com/watch?v=iQo5vihSMeY
Old Jan 12, 2012 | 09:50 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 97 Accord main relay issues?
Although the main relay may be bad, before you blame it, verify that your battery is fully charged, can hold a charge, and that the connections are clean and tight.
Peruse through this link for more details...
http://techauto.awardspace.com/mainrelay.html
Old Jan 14, 2012 | 09:57 AM
gogydm's Avatar
Battery and main relay were good. It turned out my friend forgot to ground the ECU. It is the ground that connects to the intake manifold.
Grey_accord
Apr 11, 2014 03:31 AM
Dragon235
Sep 1, 2013 12:27 PM
koreysDad
Jul 26, 2013 06:00 PM
Lowside
Sep 27, 2011 04:45 AM
djtsmith007
Aug 25, 2007 03:23 PM
