which one is more reliable?
Old Oct 8, 2002 | 03:41 PM
1BadLude6986's Avatar
Default which one is more reliable?
i am thinking about getting cam gears for my 97 prelude and im not sure what i should get??? i want aem cams but i have heard that some people have had problems w/ them. but i have heard skunk2 cams work really well. any suggestions??
Old Oct 8, 2002 | 04:50 PM
NCSTIdriver's Avatar
Default Re: which one is more reliable? (1BadLude6986)
Go with Skunk 2. Thats what my boy is running in his built prelude. he is running 12.4's on nitrous. He hasn't had any problems at all.
Old Oct 8, 2002 | 05:14 PM
piotrush's Avatar
Are cam gears any good on a stock motor? Or are cams required to get any use out of the?
Old Oct 8, 2002 | 05:28 PM
thehondaguru's Avatar
Default Re: which one is more reliable? (piotrush)
Ive got AEM adjustable cam gears with no internal mods and when adjusted the right way they can help out, but I would get a dyno while doing it because you can hert performance with them also.
Old Oct 8, 2002 | 06:29 PM
PrecisionH23a's Avatar
these will only help you if you get them dyno tuned
Old Oct 8, 2002 | 06:43 PM
piotrush's Avatar
Default Re: which one is more reliable? (GudeH23a)
I wouldn't touch them without a dyno. But are they worth ~$200 bucks on a stock motor?
Old Oct 8, 2002 | 07:01 PM
does neone know how much skunk2 cams go for?? if so where can u get them?? cause if they r about the same as aem cams then im going to get them.
Old Oct 8, 2002 | 07:29 PM
EH2DX's Avatar
http://www.inlinefour.com
i know they have them, too lazy to check rite now , but i think they shouldn't be more than $700. keep in mind that you have to spend more for valve springs and retainers...
Old Oct 8, 2002 | 07:53 PM
piotrush's Avatar
Default Re: which one is more reliable? (BB1)
I think he meant cam gears because AEM doesn't make cams.
Check this out: https://honda-tech.com/zerothread?id=269043 Alot of people vouched for this guy, so he should be OK. Im getting my N1 from him.
Old Oct 9, 2002 | 10:06 AM
Anubyss's Avatar
I would suggest getting Skunk2 cam gears since they have more bolts (6) than the AEM gears. I am not saying that they are better or worse than any other since I have no experience with any other cam gears, but having more bolts makes sense to me. I've had it for a while now and no issues with them. It wouldn't really do you any good on a stock motor to get these things (usually around $180 for the pair). They are a must if you get camshafts though.
I have a 97 Prelude as well.
[Modified by Anubyss, 2:08 PM 10/9/2002]
Old Oct 9, 2002 | 10:10 AM
Anubyss's Avatar
Default Re: which one is more reliable? (Anubyss)
By the way, you may want the cut the valve cover if you are going to be adjusting them every time you do engine work. It will save you time in getting to them.
Old Oct 9, 2002 | 03:27 PM
rybred's Avatar
Default Re: which one is more reliable? (743lude)
but if you do cut the valve cover your chancing a rock getting into your cam gears, and if one does you can say bye to your motor.
If your worried about that, u can always make some sort of easy removable shield! The chances of that rock getting in there anyways, i think is very slim!
Old Oct 9, 2002 | 04:44 PM
Default Re: which one is more reliable? (Rybrid)
how would u make a removable sheild?
Old Oct 9, 2002 | 05:35 PM
Anubyss's Avatar
And here I thought I was ****. The chances of something getting in there is so remote it's ridiculous. Does it exist, yes but highly unlikely. I've been running this way for about a year now. I've driven in gravel and sand and such with no issues. If you want I guess you could put a hinge on the piece you cut or something along that line. That way you can just lift it up if you need to access it, then close it down after you are done. You may as well put some type of latch on the other end.
Old Oct 9, 2002 | 05:54 PM
rybred's Avatar
Just be creative, i couldn't tell u off the top of my head, but i bet i could figure something out pretty fast, if i was actually gonna do it! Doesn't have to look pretty, just protect it!
Old Oct 10, 2002 | 05:38 AM
1fast5gp's Avatar
Skunk 2 Rocks ***
Old Oct 10, 2002 | 04:32 PM
rybred's Avatar
Default Re: which one is more reliable? (1fast5gp)
Skunk 2 Rocks ***
THAT'S NOT WHAT I'VE HEARD!!!! skunk2=junk2
But maybe it's different for the lude, i don't know!
iwannarace
21
Dec 11, 2011 07:40 PM
SR200
Dec 30, 2007 12:53 AM
97_dc2
Feb 8, 2007 05:15 PM
fergy016
Jan 4, 2005 09:05 AM
jarel
Jul 1, 2002 07:44 PM
