95del sol...need new horn!
Old Jan 11, 2012 | 09:30 PM
Mats_A_G's Avatar
Default 95del sol...need new horn!
Just the horn. No wires. Broke it when i hit my front end on my old bper. Anyone know where to get it?
Old Jan 11, 2012 | 10:13 PM
Texas4door's Avatar
Default Re: 95del sol...need new horn!
Are you looking for s stock replacement?
Honda parts dealer or junkyard!
Aftermarket?
Any auto parts store can get ya set up!
Good luck!
Old Jan 12, 2012 | 09:17 AM
NOFX's Avatar
H-T White Ops
If you get it from a junkyard, check the connection. I think most horns use the same plug for sometime, but it changed in 1998 from one to two pin iirc.
Old Jan 12, 2012 | 09:22 AM
Mats_A_G's Avatar
Cool sounds good. Ill check out a junkyard!
Old Jan 12, 2012 | 09:36 AM
grumblemarc's Avatar
The Grumpiest
Marketplace.
http://www.hondamarketplace.com/show....php?t=2887088
Old Jan 12, 2012 | 09:52 AM
DSMAddicted's Avatar
OP: if you are changing horn, why go through the trouble of buying and replacing it with the cheap (and hard to hear) OEM horn? There are some clean solutions that don't take much space (can use same location) and work well with the stock horn wiring configuration.
These aftermarket solutions will ensure you're heard when a big truck is about to run into your lane or if you need to put some stupid soccer mom in her place:
Hella Supertones
FIAMM Horns
I have FIAMM horns similar to the above and they're excellent.
They sound like the OEM horns that come with other cars, very glad I've replaced my stock horn with them.
Good luck.
Old Jan 12, 2012 | 05:53 PM
NOFX's Avatar
H-T White Ops
Tbh, there are OE horns that will fit this car but sound louder.
For example, the Civic has a cute horn, but the Accord sounds better imo.
singlecamslamed
Jul 23, 2010 12:51 PM
lmike6453
Mar 27, 2008 07:04 PM
LOWLIFEHATCH
Apr 3, 2003 10:09 AM
ActiveAero
Sep 9, 2002 06:34 AM
SIK IN DA HED
Apr 24, 2002 11:54 AM
