Can Someone Tell Me What This Plug Is?
Old Jan 11, 2012 | 05:57 PM
chinaxiong's Avatar
Default Can Someone Tell Me What This Plug Is?
The car is a 91 CRX. I just need to know what this plug is and whats it's purpose. If I'm standing in front of the car looking at the engine bay this plug would be to the left by the shock tower (if I'm inside the car it would be by the right shock tower). Any help would be appreciated. TIA.
Old Jan 11, 2012 | 06:10 PM
jdmef69's Avatar
Default Re: Can Someone Tell Me What This Plug Is?
It plugs into the engine harness.
Old Jan 11, 2012 | 07:55 PM
KINGVEM^^ED6's Avatar
Dash harness to engine harness connector
Old Jan 11, 2012 | 09:01 PM
ef yu's Avatar
if you are standing in front of the car, it would be towards the left shock tower. really cant miss it. the car has no other plugs that fit into it.
Old Jan 11, 2012 | 10:32 PM
crx_si-r's Avatar
that plug has the following:
tach signal
starter signal
switched 12v power supply
oil pres switch
ground
water temp
alt
Old Jan 12, 2012 | 03:31 AM
jdmef69's Avatar
Passenger side shock tower. Near the other cabin to engine harness plug. Should be right by the fuse box in the engine bay. You can't miss it.
Old Jan 12, 2012 | 07:45 AM
chinaxiong's Avatar
tach signal
starter signal
oil pres switch
ground
water temp
alt
Maybe I was not clear on my post but this is more of what I'm looking for. I know where this plug goes to but where does the wires coming into it comes from. Is there a diagram somewhere that I can look at to find out what wire goes where? Thanks.
Old Jan 12, 2012 | 08:18 AM
jdmef69's Avatar
You mean where do the wires come from on the engine harness side or cabin harness side?
Old Jan 12, 2012 | 09:02 AM
chinaxiong's Avatar
Yea, I want to know where the wires come from the engine harness side. Instead of opening up the engine harness side to determine what goes where I'm looking for a diagram to show me where each wire comes from the engine harness side.
Old Jan 12, 2012 | 01:10 PM
chinaxiong's Avatar
Anyone???
Old Jan 12, 2012 | 01:31 PM
jdmef69's Avatar
Get a owners manual. Can I as what the purpose of this is?
Nitrozity74
Nov 22, 2017 07:30 PM
sonic47
13
Feb 10, 2010 03:23 AM
alacard
Jan 8, 2009 06:06 PM
ozrednsx
12
Oct 22, 2007 12:14 AM
DaveF
Jun 18, 2005 05:38 AM
