97 Ek hatch JDM P73?
Old Jan 11, 2012 | 01:49 PM
ConfusedEGCoupe's Avatar
Icon2 97 Ek hatch JDM P73?
Hello H-T
I apologize in advance for any noobness but I looked around and could not find answer. I have a 1997 civic with a d16y8. The ECU for that motor is searching for an FTP sensor that my car does not have therefore the check engine light is on and will always be on. (CODES: P0453, P0450) I read that a JDM ECU will eliminate the issue. I have a chance to pick up JDM P73, which is also why I'm posting I'm hoping for a quick response.
Now my question is will a JDM p73 eliminate that code? Also with it run my d16y8 for the time being? Im planning on getting a B-series swap down the line and do not want to run into same engine code problems.
Thanks in advance
Old Jan 12, 2012 | 06:20 AM
kyden's Avatar
Default Re: 97 Ek hatch JDM P73?
it will eliminate the code, but it sure as hell won't run right, nor will it pass an obd2 plug-in.
Old Jan 12, 2012 | 06:26 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
http://www.ff-squad.com/technet/code91.htm
Old Jan 14, 2012 | 07:39 PM
bump thanks for input. Is there a JDM OBD2a SOHC Vtec ECU i could run? if so what ECU would it be?
Old Jan 16, 2012 | 06:17 AM
kyden's Avatar
a jdm ecu won't connect to a scan tool.
94eg!
Mar 4, 2008 11:07 AM
paascal
Sep 11, 2007 08:41 PM
Eli Mac 67
Jul 12, 2007 06:07 PM
esoterEK..
Jul 16, 2004 12:57 PM
