90 CRX (Fuel Pump Continuos Prime)
I recently performed an OBD1 JDM D15B swap on my 1990 CRX base model. It was originally DPFI and is now MPFI (done correctly).
Using:
OEM harness
OBD1 Injectors added with no resistor box
OBD1 Dist.
Jumper harness to OBD1
Stock P28
Stock trans
Pinned correctly to the ECU
4 wire o2
Outer TPS wires switched
Motor ran perfect in an EG chassis
The motor turns over strong and starts for a brief second and dies/ sputters. I have raw fuel exiting the exhaust and i do have spark. My fuel pump continues to prime and does not shut off after 3-4 seconds. It's as if I am getting too much fuel causing the cylinders to flood and soaking my plugs. Any help is appreciated.
Using:
OEM harness
OBD1 Dist.
Stock P28
Stock trans
4 wire o2
I'm having similar problem with my 90 crx with z6 and dpfi to obd1 swap. I have a continuous CEL and it sounds like the fuel pump never stops priming and also had fuel coming out of exhaust. Using a p28 ecu, d16z6 distributor(td42u), 4-wire o2 sensor and obd0 to obd1 jumper. I'll let you know if i figure this out.
MervTeck
Feb 23, 2017 03:57 PM
Project Phoenix
Jul 18, 2010 02:55 PM
RicedREX
Jul 29, 2004 10:46 AM
MarkAngelo
May 18, 2004 03:51 PM
