FS: WW Evo IX MR with 5 Speed - MN
Old Jan 10, 2012 | 08:10 PM
pennies_hatchie's Avatar
Default FS: WW Evo IX MR with 5 Speed - MN
Hi H-T.
I've decided to sell my WW Evo IX MR as my wife and I are expecting and in need of a softer vehicle (I bought it about 9 months ago, go figure). This is my 2nd Evo so like anything, I had more experience of what to do and not to do. I have put roughly only 10k on her since I bought her and she was my daily so I racked up probably 50 miles per day/5 days a week, hence the higher miles in the short amount of time. She is adult owned, has not been to the track, mistreated, or launched in my possession. She has a clean title and no accidents and I still currently have a lien on her as well. She was previously owned by a tech from Chicago who had AMS do majority of the work and previous tune on the car.
A little background, a month after I bought her, the 6 speed transmission locked up on the highway and so I had a local shop (RS Motors) that specializes in Evo's do a 5 speed swap from an Evo 8. The original transmission will come with the sale as well. Later that month, I had RS Motors do a conservative tune on E85, she puts out 379 AWHP and 399 LBS of Torque pushing 27 PSI.
With that being said, the previous owner stated she has a stage 1 Exedy clutch and I was too broke then to replace it when I did the 5 speed swap so I left it. RS also stated that the clutch still had a lot meat left but with the extra torque, the clutch IS starting to wear. I do however, generally do not go past 4k rpm nor WOT so the clutch is fine if you drive it and it has not left me stranded or cause any major issues. I did want to replace it with an Exedy TD HD soon to enjoy the power so I bought a slightly used one with 2k daily driven miles (the discs has a ton of meat left) that will come with the car as well. That way, the new owner can enjoy the power.
The bad:
One night driving on the highway, the driver side cover of my OEM Wing flew off so I replaced with a miniwing from Ebay and taped the wholes. The wing will come with the car as well.
The trans will slightly grind in 5th if you're shifting high. I experience this a few times hence I try not to shift higher then 4k RPM. It's fine if you drive normal. I may attribute this to the clutch since it only started happening after the E85 tune (too much Torque )
With the car being a DD most of it's life, it does have normal wear and tear. There are some scratches on the passenger side (can't see it unless you're right up to the car) and the front lip has a small scratch (Pictured Below).
She has 67k on her atm and I have NOT done the 60k maintenance yet. I was planning on doing it when I swapped in the Exedy TD.
Overall, the Evo is a great car and I wouldn't be selling her if we were not expecting within the next 3 weeks. I have a stack of Maintenance records and receipts from shops/dealerships for parts and services. I just bought a daily so please no trades and she is currently being garaged and not driven. I'm located in the Twin Cities, MN and feel free to ask questions as well
Price: $23k OBO
Edit: I will take $22k if I keep the Twin Disc and Evo8 rims/tires.
Mileage:67k
VIN: JA3AH86C66U050012
Here are the slight mods:
Engine:
AMS FMIC (Installed by AMS)
AMS LICP (Installed by AMS)
PERRIN Intake Arm/Filter (Installed by RS Motors)
Stock UICP with Crushed IX BOV (Installed by RS Motors)
AMS 02 HOUSING (Installed by AMS)
AMS MBC At 27 PSI (Installed by AMS)
WALBORO 255LPH (Installed by AMS)
KELFORD 272/272 Cams (Installed by AMS)
ARP Headstuds (Installed by AMS)
REXSPEED CF Radiator Shroud
REXSPEED CF Cam Cover
REXSPEED CF Spark Plug Cover
OPTIMA REDTOP Battery
CUSCO Polished Heat Shield
EXEDY Clutch Stage 1 with OEM PP
FIC 1250's Bought New from Maperformance (Installed by RS Motors)
NEW OEM NGK Plugs (Installed by RS Motors)
5 Speed Transmission Swap (Installed by RS Motors)
E85 Tune by RS Motors
Exhaust:
Megan Racing 3" DP (Installed by AMS)
Magnaflow Muffler (sits in cat area)/Buschur TBE with Magnaflow Rear AND Bullet Rear to switch off
Handling/Brakes:
OEM MR BILSTEINS
Braided Brake Lines
Drilled/Slotted Rotors and Pads
Carbon Fiber Brake Guides
WORKS Racing Springs 1.7" F DROP, 1" R DROP
PERRIN Rear Sway Bar
PERRIN Rear Stout Mounts
PERRIN Rear End Links
Wheels:
MR BBS/Michelin Pilot Sports AS+
EVO 8 Enkei Rims with Brand New Blizzaks for winter (Currently on the car)
Interior
Factory MR Gauges
APEXI Turbo Timer
REXSPEED CF Arm Rest
OEM CF E-BRAKE HANDLE
OEM IX RECARO SEATS
OEM MOMO STEERING WHEEL
CUSTOM WHITE "EVO" ENGRAVED DELRIN SHIFT ****
-Exterior
OEM HID USDM Headlights
OEM JDM Rear (Bought new from Driveline) - Modified OEM USDM Crashed Beam
OEM SE Front Lip
PERRIN Shorty Antenna
30% WINDOW TINTS
CUSCO POLISHED HEAT SHIELD
REXSPEED CF Side Skirt Spats
REXSPEED CF Hood Vent
REXSPEED CF Pillar Trim
OEM Window Visors
Extras That Aren't Shown:
OEM 6 Speed Trans
2 Sets of Evo Rims (9/8)
OEM 9 Wing (Missing Driver Cover)
OEM 9 USDM Rear Bumper w/ REXSPEED CF Heat Shield
Exedy TD HD Clutch Kit
REXSPEED CF Mirror Cover
Current Pictures
(ARC Shift **** will not be coming with the car)
Pictures during the Summer
Old Jan 10, 2012 | 08:20 PM
Sinople1's Avatar
Default Re: FS: WW Evo IX MR with 5 Speed - MN
Bump for a fellow ww evo owner!!
Old Jan 11, 2012 | 05:58 AM
Up
Old Jan 11, 2012 | 06:06 AM
BSERIEuS's Avatar
DO WANT!
congrats on the addition to the family. bump for an OG HT member.
Old Jan 11, 2012 | 06:14 AM
rayvo's Avatar
bump! i miss mine... is that the bushar turbo manifold?
Old Jan 12, 2012 | 05:35 AM
Just stock
Old Jan 14, 2012 | 07:29 AM
b18b1turbo's Avatar
Nice! bump for a EVO owner
Old Jan 14, 2012 | 03:15 PM
AJS's Avatar
AJS
want.. bumP!
Old Jan 17, 2012 | 01:27 PM
up
Old Jan 17, 2012 | 11:50 PM
swpdb16's Avatar
As a fellow EVO owner i have to say your asking price is a bit HIGH
ALL of your aftermarket Parts dont add to the value of the car
My advice is put it back to completely stock
It will sell faster and for better money just my .02
All have my buddies been through this and they all did as i said car sold within a week
Old Jan 18, 2012 | 12:54 AM
Thanks for your .02 . Nada's clean retail is about $22k. With the mods, she being wicked white, a IX, and a MR, I'm confident that im pretty close to where I need her to be and that's $22k. ATM, I do have a few serious buyers locally and I did have a few that were just unable to get the loan for her. I'm sure the right buyer will come along
Old Jan 18, 2012 | 01:37 AM
OnlyJosh's Avatar
Very nice evo!
Wish i had a real job to afford this
Old Jan 18, 2012 | 06:50 AM
AJS's Avatar
AJS
Considering a car payment for this.... def. going to check it out if you've still got it in a month!
Old Jan 18, 2012 | 09:34 AM
Cap'N Chronic's Avatar
bump for a sick evo.
Old Feb 2, 2012 | 05:56 PM
Up
ILLuSiv3
Sep 11, 2011 06:25 AM
DDTECH
Aug 8, 2011 03:40 PM
KID_DEATH
May 28, 2007 05:58 PM
PatrickGSR94
Mar 29, 2004 05:19 PM
