Driver's side mount bracket bolts(GSR)
Old Jan 10, 2012 | 04:56 PM
sextav6's Avatar
Default Driver's side mount bracket bolts(GSR)
Does anyone know what the part number for the driver's side mount bracket bolts is?
Looking at the link below shows the mount, but not the mount bracket, nor the 3 bolts that connect the bracket to the block. Need em pretty bad, will call Acura tomorrow if no one knows, thanks in advance.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Jan 11, 2012 | 06:25 AM
sextav6's Avatar
Default Re: Driver's side mount bracket bolts(GSR)
Seriously? Well how about bolt length and thread pitch? I am pretty sure the bolts are 14mm heads
Old Jan 11, 2012 | 07:09 AM
sextav6's Avatar
just called 2 different acuras and they were no help. I looked through every schematic on delray acura's page with no luck either.
closest i can get, on this schematic you can see the bracket i am referencing, in between the two pulleys
or here, #8 and #9 reference the engine mounting bracket, but doesnt show the bracket(or the bolts) itself
has noone had to spec these bolts before?
Old Jan 11, 2012 | 07:55 AM
sextav6's Avatar
found em, #'s 20 and 22
flanker
Dec 8, 2014 01:26 AM
mercutio_07
Mar 19, 2008 04:35 PM
XkjeldorX
Jun 21, 2006 01:49 PM
.Radical_Edward.
Jun 9, 2006 08:11 PM
EKRacer
Mar 24, 2004 07:02 AM
