Turbohatchsoontobecoupe build... 96Gsr
Old Jan 10, 2012 | 04:52 PM
turbohatch96y7's Avatar
Default Turbohatchsoontobecoupe build... 96Gsr
I got back some time so I figured ill build this motor finally and make some more powa!
I've had this motor for about 4 years 2 boosted soo I think some pistion and rods are gonna finally make its way in.
This motor was boosted last year and made 350 to the wheels can't rember exactly but it ran good and never gave me prooblems. Ill post up some pics of what I'm doing now and along the way as it makes its journey into the hx coupe I have. It gets about 40mpg as is but it needs more *****. I took apart my harness and resleaved it its about half way done heres the pics.
The old motor
Then I thought I bent some some valves after changing my headgasket. Turns out my studs are stretched.
Heres the head fresh from the shop. Romay head repair on olympic in commerce of anyone wants to know where to take a head and get good results.
heres the block
My ported manifold I plan to port alot more and smoothen out everything I could..
My harness before
After
Old Jan 11, 2012 | 11:37 AM
Default Re: Turbohatchsoontobecoupe build... 96Gsr
If anyone can help with making the pics show up ill paypal you 1 whole dollar.
Old Jan 11, 2012 | 11:48 AM
rich7777's Avatar
Profile settings > Edit options
Then make sure you have this bottom option selected (thats highlighted in blue) Then upload everything manually.
Old Jan 11, 2012 | 12:20 PM
Thanks rich ill paypal the dollar to u. But im still just getting that little blue box.
I put the url in between the img tags and thats all I get do I need to use smething besides flickr?
Old Jan 11, 2012 | 12:29 PM
rich7777's Avatar
Hahahaha, don't worry about the dollar man. I'm always glad to help . Have you selected that blue box & has you message screen changed ? I've never used flickr to be honest, i use photobucket. It maybe better off if you just upload them directly from your pc/laptop. That is unless someone else can chime in ?
Old Jan 11, 2012 | 12:35 PM
Haha I think I got it. I used the bbcode insted of the html and I can see seem them now. I'm at work ill organize this later thanks rich
Old Jan 11, 2012 | 01:20 PM
flatblack-h22's Avatar
with flickr its kind of harder to the get the url, so what i do is click on the image so it blows up with the gray screen. right click and click a size. then right click on the image and get the url. then just post it in between the code
Old Jan 11, 2012 | 01:39 PM
Builda'Teg_92's Avatar
Hope you get this picture thing figured out, i wanna seeee ha. idk i just use tinypic and copy the code it gives me??
Old Jan 11, 2012 | 02:21 PM
I put two pics up that I can see can anyone else see them?
Old Jan 11, 2012 | 02:33 PM
i see wire harness and the motor...
Old Jan 11, 2012 | 02:34 PM
and alot of links lol
Old Jan 12, 2012 | 12:00 PM
Okay I got the pics organized im going to try and finish the.harness tonight after work and then move onto porting my intake manifold.
Old Jan 12, 2012 | 12:23 PM
The stock manifold? Will you be opening it up and porting the plenum as well? or just the runners?
Old Jan 12, 2012 | 12:26 PM
Also are you running oversized valves?
Old Jan 12, 2012 | 12:45 PM
Yeah I ported it before. I removed the whole section with the butter flies and got smaller bolts and ported the chambers inside the manifold. And I ported the inlet but I can take off alot more material in certain areas and I got a new bit to use so ima have at it some more. Ill take pics swhen I have ot apart.
The valves are stock it has rocket valve springs and ferrea valve guides other than that its stock.
Old Jan 13, 2012 | 01:08 AM
rich7777's Avatar
Looking good !!! what cutters/stones are you using to port that manifold ? I need to port match my inlet manifold to the head soon.
Old Jan 13, 2012 | 09:05 AM
Heres the bit im going to use. I just bought this it cost 19 bucks. Its made for metal but im gonna use it really light on the aluminum.
Old Jan 13, 2012 | 09:15 AM
Damn...agressive looking lol
Do you plan to smooth it out a little after using that bit? like use that to cut away then another to get it semi smooth.
Old Jan 13, 2012 | 09:44 AM
Yeah after that bit ill hit it with some low grit sand paper than a fine grit to smooth it out. Maybe a light polish. Maybe go to bed bath and beyond idk idk if well have enough time. Lol (old school)
Old Jan 13, 2012 | 10:05 AM
rich7777's Avatar
Looks like your going to have some fun Is that a carbide cutter ?
Old Jan 13, 2012 | 10:10 AM
Very sweet...i saw info about when you max out the port design on the gsr manifolds i beleive it flows the same cfms or just a LITTLE less than the performer x, i would take on the diy but i work so much and never have time so ill just end up buying a manifold for my turbo gsr. But hats off to you
Old Jan 13, 2012 | 10:36 AM
Yeah its a carbide bit. I have a couple others ilk use too.
These manifolds flow pretty good. I made good numbers with it my last tune so I didnt see a reason to upgrade just yet. Ill post pics tonight with the progress I make.
Old Jan 13, 2012 | 12:59 PM
civicjunkie17's Avatar
Subscribing to this. It looks promising! Good luck man.
Old Jan 14, 2012 | 03:16 PM
H22AFerio's Avatar
Good Stuff
Old Jan 15, 2012 | 01:45 AM
rich7777's Avatar
Any updates on the manifold ?
