LS Cluster Swap
Old Jan 10, 2012 | 03:56 PM
slicksdude's Avatar
Default LS Cluster Swap
Whats up honda-tech hope u guys can help!
I did an Ls cluster swap into my 89 crx si.. from past research the cluster seems to be off a 95. I did the swap and wired it up as indicated off some threads I found on google. The thing didnt work!! the diagrams are all wrong!!
How can I test each wire individually??.. I tried using just the power to test them one by one but not all of them light up. Do some need to be ground to work? HELP PLEASE!!
Cluster errors:
Hit left or right blinker= rpm's jump up and down
Gas guage= either past "F" or "E"
Turn on headlight= Dimer doesnt work
Check engine= doesnt work
alot of wires are wrong this thing a headache
Old Jan 10, 2012 | 04:50 PM
jdmef69's Avatar
Default Re: LS Cluster Swap
Did mine with a few write ups worked for
Me. Did you soder connections and such. Use the Pin out for the ls cluster and for the ef cluster match what's wires do what. Simple.
Old Jan 10, 2012 | 05:16 PM
slicksdude's Avatar
I haven't soder them yet I wanna make sure there correct with the proper wire before I do so. Do you have a link to the teggy diagram u used? Im having a hard time finding one.
Old Jan 10, 2012 | 05:37 PM
jdmef69's Avatar
94 Integra Gauge Cluster Pinouts
1. Seat Belt ----- (red/blue)
2.
3. Fuel Gauge ------- (yellow/white)
4.
5.
6. Vss ---- (orange) *will need to add
7. Trunk ---- (Green)
8.
9. Dash Brightness --- (Red)
10. Gauge Lights -- (red/black)
11. 12v Power --- (Black/Yellow) *can be used for VSS power
12.
13. Left Turn signal --- (Green/Blue)
14. Right Turn Signal -- (Green/Yellow)
15. High Beam --- (Red/Green)
16. E-Brake Light -- (Green/Red)
1.
2.
3.
4. 12v Power --- (Yellow)
5.
6. Ground ---- (Black)
7. Coolant Temp -- (Yellow/Green)
8.
9. Battery Light/Alternator -- (White/Blue)
10.
11. Oil Pressure ---- (Yellow/Red)
12. Check Engine Light -- (Green/Orange)
13. Tachometer --- (Blue)
90-91 CRX gauge cluster pinouts
1. Left Turn ---- (Green/Blue)
2. High Beam ---- (Red/Blue)
3. Coolant Temp -- (yellow/Green)
4. Dash Brightness ----- (Red)
5. Gauge Lights ----- (Red/Black)
6.
7. E-Brake ---- (Green/Red)
8. Oil Pressure --- (yellow/red)
9. Check Engine Light ---- (Green/Orange)
10. 12v Power ---- (Black/Yellow)
11. Battery/Alternator Light ---- (White/Blue)
12. Tachometer --- (Blue)
1. Ground ---- (Black)
2.
3.
4. Trunk ---- (Green/Black)
5. Seat Belt ---- (Blue/Red or Blue/yellow)
6. Fuel Gauge --- (Yellow/White)
7. 12v Power ---- (Yellow)
8. Right Turn --- (Green/Yellow)
90-91 Crx pinouts ---------------- 94 Integra Pins added
1. L Turn ---- A13
2. Hi Beam --- A15
3. Coolant Temp --- B7
4. Dash Brightness --- A9
5. Guage Lights --- A10
6.
7. E-Brake --- A16
8. Oil Pres --- B11
9. CEL --- B12
10. 12v Power --- A11
11. Battery/Alternator -- B9
12. Tachometer --- B13
1. Ground --- B6
2.
3.
4. Trunk ---- A7
5. Seat Belt --- A1
6. Fuel Guage ---- A3
7. 12v Power --- B4
8. Right Turn --- A14
thats how mine turned out and everything works.
Old Jan 10, 2012 | 05:49 PM
slicksdude's Avatar
Awesome Brother thanks!
Il be rewiring the thing this weekend hope this solves the problem. no homo
Old Jan 10, 2012 | 06:13 PM
jdmef69's Avatar
Haha it's cool. Just make sure you use the 89 cluster pin out since I had a 91 it's different but the ls is the same just match up the functions.
1SLOW90ED
Jun 8, 2006 09:32 PM
Absentmind
Apr 27, 2006 03:28 PM
88rexboy
Mar 31, 2004 08:42 AM
wdyno
May 9, 2002 06:08 PM
