Does width matter for rims?
Old Jan 10, 2012 | 02:55 PM
NewtoCivics's Avatar
Default Does width matter for rims?
So right now I have some cheap knockoff 16" rims on my civic. I bought the car with the rims/tires. I've tried like hell to find the specs on them to no avail. I don't know the offset, the backspacing or anything. The tires I currently have on them are 205/45 ZR16's. The car is dropped about an inch. I do have an issue with the outside part of the tire rubbing on the fender. So my question is can I get away with a slightly narrower/taller tire without worrying about the tire rubbing under the fender? I'm not sure how the width/height plays into the size of the rim. If I need to I guess I can buy new rims but I'm trying to avoid that cost atm.
With that said are there any pros/cons to running a narrower/taller tire vs. the current setup I have? Aside from not rubbing on the outside?
Old Jan 11, 2012 | 10:48 AM
toyomatt84's Avatar
Sanji
Default Re: Does width matter for rims?
Yes, there are pros/cons to running narrower tires. Most significant of which, would be if the tire isn't properly sized for your car you could have issues braking.
The wheel width is extremely important when trying to fit the wheels on the car. And the offset measurement is a measure from the center of your wheel (where width comes in to play as well).
Old Jan 12, 2012 | 05:09 AM
Okay. Thanks for the info. I'm going to keep reading up on it so when it comes time to buy new tires(and possibly new rims) I know wth I'm doing lol. I'll have to measure my rims and find out exactly what my offset is.
Old Jan 12, 2012 | 10:27 AM
doc@tirerack's Avatar
normally the wheel size and offset (ET) is stamped on the back of the wheel somewhere.....
Old Jan 13, 2012 | 05:09 AM
Oh awesome! Thanks! I'll have to check that out if I get time tonight. We just got like 5 inches of snow last night though lol. But at least I'll know what size I can get.
Oh and is there a recommended offset, backspacing, and toe I should run? Or is that something I can leave in the hands of the guys who do my tires/alignment?
Old Jan 13, 2012 | 07:52 AM
toyomatt84's Avatar
Sanji
Offset and Backspacing are wheel sizing references, and yes there is a range that you may want to stay within to make sure the car performs properly and safely. Toe is an alignment specification. Your toe should be zero, by the way. Otherwise you're going to chew through tires.
Old Jan 13, 2012 | 08:43 PM
Thanks for the help Toyo. When I do end up getting new tires and an alignment I'll be sure to double check that stuff.
Old Mar 25, 2012 | 05:14 PM
Datsun1200's Avatar
Hey Doc@TireRack
I am new here and cant start a thread but you seem to know some info., possibly my answer.
Could you tell me if a 7 inch Rim will fit a 185 60/14 tire?
thanks
Old Mar 25, 2012 | 05:39 PM
toyomatt84's Avatar
Sanji
Originally Posted by Datsun1200
Hey Doc@TireRack
thanks
Yes it will.
2kdrift
Suspension & Brakes
Nov 6, 2015 12:19 AM
tyronne1126
Honda Civic (2006 - 2015)
23
Mar 30, 2009 12:58 AM
ITRICED
Mar 22, 2009 09:34 AM
willu707
Jan 24, 2009 09:59 AM
vtec Hart 5150
Mar 2, 2007 07:37 PM
